Tom's Hardware > Forum > Wireless Networking > Range & connectivity > Connection Speed Drop: DLINK DI-524 & Intel 2200BG
Forum Wireless Networking : Range & connectivity - Connection Speed Drop: DLINK DI-524 & Intel 2200BG
AP : DLINK DI-524 Rev A with Latest Firmware version 1.2.1
LAPTOP A: DELL D600 with a DLINK DWL-650+ 802.11G 54M Network Card (in PCMCIA Slot)
LAPTOP B: HP NC6230 with a Intel 2200BG Network Card Integrated
WEP 128 bit .
Problem:
At the same location (about 15 feet away from AP) , The D600 works prefect at 54M's speed . While the NC6230 's connection speed is very unstable. First it conencted at 54M succesfully , Then the speed start to drop to 12M quickly . I try to ping the AP to see how many packet were lost , First several minutes it works prefect but with the speed drop , more and more packet were lost . Finally I can't conect to the AP . I have to disable/enable the 2200BG again to get it work for another 3 minutes ....
During the entire period my D600 works prefect .
Another test I have done is disable the 2200BG in the BIOS and plug the DWL 650+ into the slot , the network works fine.
Looks like the Intel 2200BG does not like the DLINK stuff ...
Does anybody have similiar experience ? How can I get it out ?
Thanks!
Sponsored Links
Read this article it will give you an insight on how different mfg play or not with each other.
http://homepage.mac.com/techedgeez [...] otout1.htm
This link tells you what chip set your mfg is using.
http://www.linux-wlan.org/docs/wlan_adapters.html.gz
Reply to blue68f100
There are 1041 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
