Hi,
I just put together a new Core 2 Duo E6400 build, my first new computer in 5 years, and everything is running smoothly, except the video cards temp is 65 C. Is that normal? It sounds hot. Will it damage the video card? It's a Sapphire X1950Pro 256 MB Card. The system temp is at 45, and the CPU is also about that.
BTW, I checked this out while doing normal tasks... I wasn't playing any games. And my case is well ventilated: Centurion 5, 80mm in front, 120mm in back.
Any ideas? Thank you! I'm afraid if I play games my card might burn up!
Bruce
Bruce
