I am having problems with this ASUS board not booting. All new system that booted about 5 times into BIOS kept hanging there. Flashed BIOS from 0401 to the latest 0503. It flashed properly, however on the reboot after the flash now nothing..repetitive 10 sec beeps, no BIOS at all. When I remove all RAM and boot it the beep changes to 1 long 2 short which according to ASUS is telling me BIOS is OK, just memory is bad..sigh. So back and forth between tech support....I Call ASUS they say it is RAM..call Corsair they say it is the MOBO. Asus says the RAM I am using is compatible even though it is not on the Qualified Vendor List. Systen did not run long enough in BIOS to even attempt to set memory timings, let alone anything else. Corsair said that this MOBO does not like 4 sticks of memory????? 8O Hello!! Why the does it have 4 slots then??? I am going to order another BIOS for my 7 day old MOBO. Any one else have any suggestions or similar issues with this Memory and Board? Because of my location..I am in the Arctic..so shipping things back and forth is expensive and time consuming..so I am trying to narrow the problem down.
4 gigs because I was planning to run XP or Vista 64bit...but wanted to get it actually running first on XP pro. Yes I have tried 1 and 2 sticks as suggested by Corsair tech support. In every slot in almost every concievable combination also as suggested by tech support. And yes I have checked every connection..including the CPU. So yah..I guess BIOS chip and go from there? Short of returning MOBO that may be the quickest solution. I also sadly have no other systems nearby to test the RAM on.
I had similar problems, after installing a further 2GB of GSkill DDR6400 with the same timing settings of 4-4-3-5, the board will run for a while and then a BSOD. If I remove these second pair of Sticks all is ok. For the life of me I could not and still can't find the Quality Vendor list form Asus! We all know that Asus support sucks!!! My understanding is just that this particular M/Board don not like 4 sticks of RAM as noted by Crosair or was it Kingston?
My advise would be to build another system with that extra pair of RAM u guys have, that's what I did.
Had the same problem . I tried all sorts , then read in the manual that this motherboard simply will not boot at all with a flat battery ,
Tested the Battery and yes it was flat , replacing it solved all my problems , .
Message edited by Bazzerbill on 11-03-2009 at 01:21:13 AM
