Running Dual 8800 GTX. WHat kind PSU do i need?
  • Power Supplies
  • Gtx
  • Components
Last response: in Components
November 18, 2006 5:53:37 PM
If i Only want ONE PSU.. which one do i need to get?? i know its 2 6 pins per GTX so which one is powerfu lenough to support this setup?
AMD 6000
M32N2-Sli Wifi
2 GB DDR oCZ Titanium
1280 GB HD ( Seagate 320 GB SATA II x 4)
Windows Vista Ultimate
Ati 650 PCI
Dual Evga 8800 GTX
More about : running dual 8800 gtx kind psu
November 18, 2006 8:46:07 PM
Well, if you manage to spend that amount of money on 2x Geforce 8800 GTX, you should have no problem going after the Enermax galaxy 1kW (if the card gives you a PCI-E power adapter, perfect to use it on spare rails that you aren't using on the drives)
November 19, 2006 4:26:13 AM
Funny. Someone will spend $1200 on just the graphics subsystem but will cut corners and not get the fastest processor available.
November 19, 2006 5:19:03 PM
Ok first of all. I do at the moment prefer AMD due to the float point multiplier are WAY WAY better on AMD than INTEL. Secondly how am i cutting corners when i basically have the best of the best? THe 8800 Ram aint worth jack since they dont have low latency yet. When they do, maybe i will pick one up. Until then i stick with what works for me.
Thirdly IF the enermax 1kW will fit in my Antec 180 B Case without any modifications i will get it. If not i will just wait on Thermaltakes 1KW or 1.2 KW
November 19, 2006 6:04:25 PM
At stock speeds an Intel should still beat that AMD... and I'd bet the farm on which had the most overclocking headroom. When you seemingly have an umlimited budget, I just don't see settling for anything but the best. I'd either choose either Intel Extreme processor over that AMD.
And for the record... I have an AMD X2 in my gaming desktop.
