Yes, it will work but use the Vista driver in Windows 7. Before downloading and installing the driver on your computer, check whether your Vista is running on 32-bit or 64-bit system type. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
You can download the driver using the links below:
http://bit.ly/cd4MzI (for Vista/Windows 7 32-bit)
http://bit.ly/c4xCtN (for Vista/Windows 7 64-bit)
