Hello everyone,
Ive read the forums here for quite some time and found my solutions to many computer building questions ive had from time to time, however now i got a bunch of questions cause im building a new rig for gaming for myself.
My budget is around $4k and i have the ridiculous flaw of always wanting the absolute best thing I can buy for gaming even if its more expensive and something that is slightly less expensive would give the same if not a little less performance. Not me i want the best performance possible If I can afford it :twisted:
Im going to be using this computer for gaming, Photoshop Graphics for my photography, and developing for websites and programming, as well as general web surfing and music listening. I already have a 22" Dell LCD and a Klipsch Promedia 5.1 so im set with those although if i have extra cash at the end i may double up my LCD's and get a second 22". I will be mainly using 1600x1200 res on most apps and games. I dont really plan to overclock too much, maybe a little depending on how my system runs initially and how the heat does on it. My computer room is very hot during the daytime so I need it all to be relativly cool, and preferably quite of course.
Anyways wihtout further ado, here is what im planning but i need a little help on my build (will it be compatible, is some of the parts im choosing not as good as others etc...)
CPU: E6800 Core 2 Extreme (all reviews ive seen dont favor the quad core processor so ill skip it for now unless im missing how this processor will react with DX10 games.)
Graphics: 8800 GTX x 2 running SLI (not sure which brand to go with, are there any brands who stand out to anyone for better components or running cooler or better warrenty? I was thinking BFG cause they used to be the best.)
Mobo: Asus P5N32-E SLI (im having a rather large conflict with this one. Should i go with the striker extreme, will spending the extra money for more bells change the performance? Are there any other good boards that do SLI and accept conroe processors? Should I wait till another quality gameing mobo comes out?)
RAM: 2 Gigs of DDR2 PC8000 Dominator Corsair memory w/ the little fan thingy on top (Are there any other sticks that are better than this in performance? Does the Airflow thingy cause alot more noise?)
Storage: WD 10k RPM Raptor HD's at 150g x 2 running Raid 0 or 1 (Anything better?)
Sound: Creative Soundblaster X-Fi Xtreme Gamer Fatality (any difference between this card and the cheaper X-Fi soundcard?)
Case: C80 Stacker or the Silverstone T7 something (will these cases fit this system? Which one is the case with better heat disapation and/or airflow? Any others that you think would be better picks? How noisy are these with full compliment of fans? Any chance of using a water cooling system with this case?)
PSU: Enermax galaxy 1kW (any PSU's that are better, cooler, less noisy?)
CPU Fan/Heatsink: No clue! (Need some help on best ones to choose for the E6800 Core 2 Extreme)
Case Fans: No clue! (Need some more help with a good brand for quite fans, maybe a little flashy too 8) )
Im planning on building the system between now and the end of January. Should I get Windows Vista when it comes out or just hang on to XP Media?
Sorry I know this is alot of questions, but any help, recommendations would be appreciated! Thanks ahead of time
