well, my AMD 3700 just isn't handleing the pace anymore, and my Geforce 5200 just refuses to run certain games... so i'l looking to upgrade, and since i want to go back to Intel, i've decided to build a whole new system (and leave my old one as a server) so i'm looking for a rig that should be able to handle most games
i've been looking around for a while now, and i'm almost convinced to try to build my own system rather than rely on the stock models... (although alienware 7500 series looks enticing....)
so i've put together a list of components, and i was hoping a few people here might be able to help me refine what i need... but being in Oz limits my selection somewhat
CPU Intel Core 2 Duo E6600
CPU Intel Core 2 Duo E6300
Case Thermaltake Armor (LCS maybe)
Mobo Asus Striker Extreme: NVIDIA nForce 680i SLI*
Mobo Asus P5n32-e nForce 680i
Mobo BFG nForce 680i
PSU Thermaltake W0131 ToughPower 850W
RAM Corsair TWIN2X2048-6400C4PRO
GPU Asus 8800GTX
GPU BFG 8800GTX
alright, first off, Motherboard... i was interested in the striker, but unfortunately it looks as though it may be a little hard to get a hold of at the moment, but at the same time i'm planning on building this mid-late december, so it should be avaliable then... right? otherwise, i might have to go with either the lite version of the striker (p5n23-e i think) or the BFG board (which a friend recommended)
the only thing undecided about the case is if i'm going to go with the LCS version or not (a little help here would be appreciated, i've never seen let alone built a LCS system, would it be too much for a beginner?)
as to the CPU, i'm not sure if a 6300 or 6600 should suit.... i'll probably upgrade to a QX 6700 or equivilant once the price drops from lunar orbit, so would a 6300 hold out till then i wonder (aside from the extra $200 i would save)
the Graphics card, again i'm tossing up between BFG and Asus, and i'll probably go with whichever mobo i get since both are avaliable (and are the only two avaliable through my supplier ATM) and are the same price...
and finally, a quick question about ram timings, is higher or lower better? (with all the guides i've read, they just talk about changing them to whatever, but don't mention if 3,3,3 whatever is better or worse than 5,5,5....)
GPU Asus 8800GTX
GPU BFG 8800GTX
