XP/ME Network problem
Forum Windows XP : Windows XP General Discussion - XP/ME Network problem
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have two machines that I would like to network using a crossover cable but
am having problems.
Basically, I can't get the 2 Machines to see each other.
I have run Network Setup wizards to no avail. I have scoured the net for a
way to solve my problems and tried numerous suggestions, still no luck.
Many places on the Net state that setting up a simple network between two
Windows machines using a crossover cable is easy!!! I have considered buying
a Hub but for all I know (not a lot but learning fast) I may well be no
better off. Any suggestions would be most welcome.
Here are the details:
Machine 1
OS: XP Home
NIC:
VIA Rhine II Fast Ethernet Adaptor (built into the Motherboard).
Selecting properties of the NIC in Device Manager, the settings are as
follows:
Advanced Tab:
Adaptive Interrupt: Enabled
Connection Type: Auto-Negotiation
Flow Control: Hardware Default (Auto)
Network Address: Not Present
Receive Buffers: 64
Transmit Buffers: 64
When viewed through Network Connections it shows:
Name: Local Area Connection
Type: LAN or High-Speed Internet
Status: Connected
Device Name: VIA Rhine II Fast Ethernet Adaptor
If I right-click on this it shows the following Local Area Connection
Properties:
General Tab: Client for Microsoft Networks (ticked)
File & Printer Sharing for Microsoft Networks
(ticked)
Internet Protocol (TCP/IP) (ticked)
Properties for this are:
Use the following IP Address: (Selected)
IP Address: 192.168.0.1
Subnet Mask: 255.255.255.0
Default Gateway: Blank
Use the following DNS server address: (Selected)
Preferred DNS Server: Blank
Alternate DNS Server: Blank
Authentication Tab: Enable IEEE 802.1x. (ticked)
EAP Type: Smart Card or other
certificate
Authenticate as computer when computer
information is available (ticked)
Authenticate as guest when user or
computer is unavailable (ticked)
Full Computer Name: MACHINE1
Workgroup: MACHINES
IPCONFIG Results:
Windows IP Configuration:
Host Name: Machine1
Primary DNS Suffix: Blank
Node Type: Unknown
IP Routing Enabled: No
WINS Proxy Enabled: No
Ethernet adaptor Local Area Connection:
Description: VIA Rhine II Fast
Ethernet Adaptor
DHCP Enabled: No
Various drives/folders are set as Shared
Firewall is off.
This machine also has a ADSL Broadband Internet connection via a USB Modem
Machine 2
OS: WinME
NIC:
SMC EZ Card 10/100 (SMC1211TX)
When I select Network within Control Panel the following is displayed:
Configuration Tab: Client for Microsoft Networks.
Properties for this are: Logon and
restore Network connections (selected)
Microsoft Family Logon
Driver Type Tab. Click the type of the
network driver to use:
All greyed out - nothing selected
Bindings Tab: TCP/IP (ticked)
Advanced Tab: Link Speed/Duplex Mode: Auto Mode
Network Address: Not present
TCP/IP
IP Address Tab: Specify an IP Address (selected)
IP Address: 192.168.0.2
WINS Config Tab: Disable WINS Resolution
Gateway Tab: All Blank
DNS Config Tab: Disable DNS
NetBIOS Tab: All greyed out but 'I want to enable NetBIOS over
TCP/IP protocol' is selected
Advanced Tab: Allow binding to ATM. Yes is selected
Bindings Tab: Client for Microsoft Networks (ticked)
File and Printer sharing for MS Networks
(ticked)
MS Family Logon (ticked)
Browse Master: Automatic
LM Announce: No
Full Computer Name: MACHINE2
Workgroup: MACHINES
Firewall is off.
IPCONFIG Results:
Host Name: Machine1
DNS Servers: Blank
Node Type: Broadcast
NetBIOS Scope ID: Blank
NetBIOS Resolution Uses DNS: No
0 Ethernet Adaptor:
Description: NDIS 5.0 driver
DHCP Enabled: No
Primary WINS Server: Blank
Secondary WINS Server: Blank
Sponsored Links
In article <cqq4hd$c6r$1@newsg2.svr.pol.co.uk>, bh@hb1.com, Ben Hardy
says...
> am having problems.
It appears that "Family Logon" on ME may be the culprit....Switch it to
network. Unless of course this was already suggested..... ;0(
Reply to bytor
Hi,
Well, on the ME machine I have both Client for MS Networks and MS Family
Logon
Do you mean I should remove MS Family Logon?
"ByTor" <ByTor@snowdog.com> wrote in message
news:xV0Ad.29744$XV5.13476@fe04.usenetserver.com...
> says...
>> but
>> am having problems.
>> a
>> buying
Reply to Anonymous
In article <cqq6f8$pc4$1@newsg4.svr.pol.co.uk>, bh@hb1.com, Ben Hardy
says...
> Hi,
> Logon
You don't neccessarily have to remove it just switch to it, use that
instead. You'll have to forgive me it's been quite awhile since I used a
crossover but I'll continue to help & re-review your settings if this
does not help.........But, technically "both" computers should be using
"network logon"
Reply to bytor
Thanks for your advice.
Err, how do I 'switch to it"
news:nb1Ad.34133$oA3.32229@fe64.usenetserver.com...
> says...
>> Hi,
>> Logon
> "network logon"
Reply to Anonymous
In article <cqq7e0$c5k$1@newsg4.svr.pol.co.uk>, bh@hb1.com, Ben Hardy
says...
> > says...
> >> Hi,
> >> Logon
> > "network logon"
Go back to the properties of your local are connection and in the drop
down area under all your protocols you will see "Primary Network Logon"
switch it to "Clients for MS Networks"
Bare with me as I'm not working off of a ME partition to give exact
details....It's been awhile.
Reply to bytor
says...
Have you seen this site yet.....It's def informative.
http://www.windowsnetworking.com/
Reply to bytor
Oh yeah, I scoured that site earlier but it's still not working here.
I tried your last suggestion re: Client for MS Networks and MS Family Logon
but no luck - I can't ping one machine from the other.
I've checked out the crossover cable and it's ok
I tried 2 different NICs in the WinME machine (both cards worked on other
machines)
news:DC1Ad.9138$596.2166@fe80.usenetserver.com...
> says...
Reply to Anonymous
Hi Ben,
Just a few thoughts...
I have purchased crossover cables that were not configured properly. Have
you tried another crossover cable?
I saw where something about one of your network card drivers choice was
greyed out. That could be an indicator that something is not right.
The client should be the same, i.e., both set for Client for Microsoft
Networks.
When you set up your primary computer for a home netowrk, did you make a
disk to use on the ME computer? If not, try that. The disk will assist in
getting the ME computer ready for networking with XP.
If you are pretty well stymied, do you know someone you can trust to take a
look at it for you?
Check your CONTROL PANEL, SYSTEM, HARDWARE, DEVICE MANAGER, NETWORK ADAPTERS
on each computer and see if any errors are reported.
Excellent book to get: Microsoft Windows XP Networking Inside Out, by Curt
Simmons.
If none of this helps, let me know.
Bill
P.S. I'm a Senior LAN Administrator with the State of Indiana. I will assist
in any way I can.
> am having problems.
> Machine 1
> OS: XP Home
> NIC:
> follows:
> Advanced Tab:
> Receive Buffers: 64
> Status: Connected
> Properties:
> (ticked)
> certificate
> Workgroup: MACHINES
> IPCONFIG Results:
> Host Name: Machine1
> Node Type: Unknown
> Ethernet Adaptor
> DHCP Enabled: No
> Firewall is off.
> Machine 2
> OS: WinME
> NIC:
> TCP/IP
> (ticked)
> LM Announce: No
> Workgroup: MACHINES
> Firewall is off.
> IPCONFIG Results:
> Host Name: Machine1
> DNS Servers: Blank
> 0 Ethernet Adaptor:
> DHCP Enabled: No
Reply to Anonymous
In article <cqqa7l$c5k$2@newsg4.svr.pol.co.uk>, bh@hb1.com, Ben Hardy
says...
> machines)
Found this for ya might me muuuuuch more informative:
If you have adobe installed:
http://www.cellarstoneindia.com/ca [...] nection%20
(95-98-MeToXP).pdf
If not go to www.google.com In the search field type:
Windows ME and XP crossover cable networking
9th link down "Windows 95/98/Me To Windows XP"
Click view as HTML
It's actually quite good, as I feel you may not be "manually" assigning
IP addresses correctly and all that blah......Crossover connections are
a pain. I believe you stated you have DSL/High Speed Cable?
Why not invest a few bucks & buy your self a router.....Both machines
will have internet, and it will configure the network for you
automatically as far as addresses.........I first started with
crossover, than ran out & bought a router. There is no need for a hub as
the routers(most)function dually.
Reply to bytor
In article <V43Ad.9189$m56.1499@fe74.usenetserver.com>,
ByTor@snowdog.com, ByTor says...
> says...
> > machines)
> (95-98-MeToXP).pdf
> Click view as HTML
My next question would be is, is your cable really a "crossover?"
Hmmmmm?
Reply to bytor
Yeah, I considered the cable might be at fault, especially since the legend
on the sheath says Patch rather than crossover so I found a few schematics
on the Net which show which wires should be crossed and the cable checks out
(unless it has a break somewhere)
Yes, I've done that numerous times in both directions using both a floppy
disk and the WinXP CD
> ADAPTERS
Done that. The XP Machines' NIC is built into the Motherboard and it seems
to work as it constantly gives a message (VIA the icon in the Notification
area) such as 'Local Area connection is now connected. Speed 1OO.0MBPS'. I
also checked that I have the latest drivers for both adaptors. I tried two
NICS in the ME machine, both of which prevoiusly worked in other PCs and I
also have the latest drivers for those.
In the last couple of days I've found and read loads of stuff on Networking
and have learned a great deal. The one at
http://www.cellarstoneindia.com/ca [...] eToXP).pdf
looks excellent. I'll check it out tomorrow as it's now 2:30 am here.
Thanks for all the help and suggestions.
Maybe it'll be simpler if I get me a router. The main reason I took the
crossover option was due to reading how supposedly simple and cheap it was
for just two machines. Ah well, you live and learn!
Thanks again
Ben
"williame" <williame@discussions.microsoft.com> wrote in message
news:0E6CBE4F-470E-4EF8-AA57-73419521F72C@microsoft.com...
> Hi Ben,
> Networks.
> a
> look at it for you?
> ADAPTERS
> Curt
> Simmons.
> Bill
> assist
> in any way I can.
>> but
>> am having problems.
>> a
>> buying
>> Machine 1
>> OS: XP Home
>> NIC:
>> follows:
>> Advanced Tab:
>> Receive Buffers: 64
>> Status: Connected
>> Properties:
>> (ticked)
>> certificate
>> computer
>> Workgroup: MACHINES
>> IPCONFIG Results:
>> Host Name: Machine1
>> Node Type: Unknown
>> Ethernet Adaptor
>> DHCP Enabled: No
>> Firewall is off.
>> Modem
>> Machine 2
>> OS: WinME
>> NIC:
>> the
>> TCP/IP
>> Networks
>> (ticked)
>> LM Announce: No
>> Workgroup: MACHINES
>> Firewall is off.
>> IPCONFIG Results:
>> Host Name: Machine1
>> DNS Servers: Blank
>> 0 Ethernet Adaptor:
>> DHCP Enabled: No
Reply to Anonymous
you have answered your own question. you state that your cable sheath
says 'patch'. this is not a crossover. get a true crossover cable or
get a hub or router/switch and use your patch cables. hate to say it
but you need to read into what you are doing.
Reply to Anonymous
Well, as I said, I have checked out each ends' color coding and it's
cross-wired as it should be as compared to a standard Patch I have here
which isn't. So although it's puzzling I suppose that there's little else I
can do but get another cable or a router.
Thankyou for all your help
<bbently@verizon.net> wrote in message
news:1104208821.138983.309570@f14g2000cwb.googlegroups.com...
Reply to Anonymous
i solved my problem by going to http://www.careyholzman.com/netfixes.htm
yours Martin
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > XP/ME Network problem
There are 593 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
