Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Going from a 9800pro to a 7800GS -- Need Help!
Forum Graphic & Displays : Graphics Cards - Going from a 9800pro to a 7800GS -- Need Help!
I recently purchased at 7800GS to replace my aging 9800pro. I uninstalled everything properly, cleaned off the old drivers with Driver Cleaner Pro, and installed the most up to day forceware drivers i could find. I was expecting a substantial performance increase due to the fact that people had told me the 7800gs was roughly twice as fast as a 9800pro. Whether that is true or not...I'm not sure, but I have experienced a DROP in performance with my upgrade. My system components are as follows:
P4 Northwood 2.6gHz 800mHz FSB
1gb Corsair XMS pc-3200
120gb HD
Gigabyte MB
In some cases, I do experience a higher MAX framerate...but this is not consistant. However when there are intense battle sequences and close combat, my framerate drops to a point about 15-20 fps lower than it would be with the 9800pro under the same situation.
The best example of this poor performance is in Counterstrike: Source.
Quake 4 runs about the same on both cards and HL2 is also about equal.
Any help would be GREATLY appreciated as I am very dissapointed in the performance I have received. Thanks in advance for any advice you guys could give me.
Sponsored Links
What resolution do you play at?
Reply to enforcerfx
I have a 7800GS and it's a great AGP card, it performed above expectations in most games.
Run 3dmark05 if you can and report back.
Set your drivers to high performance mode first.
Reply to GeneticWeapon
- 0 +
Maybe you have put too much antilealising or anastrofic.
Is the card running cool enough? any card below it? cables?
Reply to slim142
Quote :
Good point here. In the graphics settings it may be set to auto apply AA and AF?
Reply to quantumsheep
- 0 +
Quote :
beware, those are only for the 8xxx series :)
Reply to pmr
- 0 +
I appreciate your quick responses! I currently run them at 1280x1024 resolution as it is the native resolution for my monitor. I hvae turned my settings in the nVidia control panel to high performance. AA and Anisotropic filtering are both set to 'application preference'. The funny thing is that my framerates don't really vary when I lower the resolution or turn off AA which I thought was very strange. Also, my framerate seems to decrease as I change settings in game and continue playing. I really don't know what that is about...
Also, I am aware of the 8800 specific drivers. Once I get home, I will post my drivers version.
Again, any help is greatly appreciated.
Reply to DWAYO83
- 0 +
Configurate the panel control to your preferences and put No antilealising. Also, in the game, make sure you put medium-to-lower settings.
That might help.
Reply to slim142
- 0 +
Thats funny thats what i upgraded to form my 9800pro except i have amd 3000+ but anywaz i dont know why it would be doing that. And i know its not AA or anti because i run half-Life 2 At 1680x? (i forgot the exact), 4x AA and 16x anti. What i did when i got the card was did a reformat b/c my system was cluttered at the time anywaz. You might just want to do that and see if that solves the problem.
Reply to dark115
- 0 +
Also,
My card rund at around 36 degrees C at idle and around 45 under full load.
Reply to DWAYO83
- 0 +
Something tells me is the drivers...
Make sure you are using Forceware 93.71
Reply to slim142
- 0 +
Okay I will check that. If I am currently using the 93.71 version, what would be your next suggestions? Would a reformat make any difference? Is there a chance spyware or something like that could be messing things up?
Reply to DWAYO83
- 0 +
I would say that there is something else that is messing up your pc. Maybe spyware as you said is eating sources.
My friend can play CS source with maximum settings and antilealising 4x with a 6600GT Athlon XP 2.0Ghz and 512 of Ram.
Reply to slim142
- 0 +
Quote :
antilealising
8O
Reply to pmr
- 0 +
I DONT KNOW HOW TO SAY THAT! :oops:
but you get the idea 8)
Reply to slim142
Quote :
120gb HD
Gigabyte MB
Not very different from my system, and I also had a Radeon 9800 prior to the current 7800GS. I have experienced a large increase in 3D performance.
One thing, 'though: the current 93.71 drivers are crap. The previous (.47, I guess) drivers are much better.
Also driver settings may be the culprit. Even with a 7800GS, I disable AA in most games. AA is great, but it really slows everything down.
For a real comparision, you have to run the current games in the same settings as you did with the 9800Pro. then you'll notice the increased frame rates. Only then you should start improving the settings on the games.
Reply to Simonetti
- 0 +
See...that's just it. I am running the games on the same settings with both cards. Like I said earlier, the card can produce brief moments of higher MAX framerate....however it drops lower than the 9800 did under intense graphical sequences. That is just very odd to me.
Something else to note: When I first start a game of CS: Source, my framerate will be between 80-90. After I play a round or so, I can go back to that same spot and look in the same direction in game and only get 55-60 fps. That to me sounds like a heat issue, but my card only gets up to 44-46 degrees C...which doesn't seem that hot to me for a graphics card.
Reply to DWAYO83
Quote :
In the past nVidia cards had problems with a few Gigabyte mobos, older ones.
The Gigabyte voltage regulators on the 3.3V rails could give only 5A, while the AGP specs required 6A on that rail. Thus the vr would overheat and the voltage would drop down to 2.2V, thus forcing the card to a lower speed setting. Thus would happen only after a few minutes, not instantly (it took time for the voltage regulators to heat up).
I suggest you call the manufacturer of the 7800GS you bought to check if they had tested the card with the specific model of mobo you have. Maybe there are issues they know about.
Also, what are the ratings of your PSU?
What is the exact model of your mobo?
Who is the manufacturer of the 7800GS?
Reply to Simonetti
I agree that your motherboard may not have proper support as it is installed right now, but I suggest you upgrade the firmware on the motherboard (flash it) and your problems may disappear. Often they make updates to handle new types of graphics cards.
Bruce
Reply to qrhetoric
- 0 +
I will check my motherboard and PSU specs when I get home. I wasn't planning on having to make further investments to get the card running right...
Reply to DWAYO83
- 0 +
My motherboard is a Gigabyte GA-8IPE1000 GT. My PSU is an Allied AL-B450E 450w.
Reply to DWAYO83
- 0 +
Do you have the lastest BIOS? make sure you have it since it might fix anything related to your AGP port.
Also, if you ask yourself why you have 90FPS in the menu screen of CS:S is because there is only a picture in the screen, like every other game always in the menu screen you will have a high FPS but once the game starts (explosions, guns, tanks) is when your FPS goes down because the card starts working.
I dont really know why you have that problem. What is the brand of your 7800GS?
Reply to slim142
- 0 +
Cold Bug? My 7800GS started to run very badly when I moved my computer to a colder room in the house. I heard about a "Cold Bug" affecting some of the Nvidia cards where they ran terrible until warmed up. It fit my profile and then I flashed the bios to remove the temperature monitoring. Since then.. all has been good. Try running 3Dmark or something first and then playing your game. If you see an improvement.. maybe its the cause.
Reply to c8ia
- 0 +
I have a BFG 7800 GS. I'm not talking about the menu screen. I'm talking about when I first enter the game and play the first round, I have higher framerate and then it slows down drastically.
Does anyone know if this particular motherboard only have 5amp voltage regulators like mentioned before?
Reply to DWAYO83
- 0 +
Quote :
Wouldn't this processor be a major bottleneck? I wouldn't think that you would realize anything close to the full potential of your new card with it......
Reply to gearbox
- 0 +
I had a 9700pro and moved to a 7800GS with a 2.8 Northwood OC'd to 3.2, and I noticed the difference.
Reply to c8ia
- 0 +
Okay, I flashed the BIOS on my motherboard and I'm still having the same problem. Does anyone know if my particular motherboard (Gigabyte GA-8IPE1000) has problems with the voltage regulators only running at 5 amps instead of the required 6 amps?
Reply to DWAYO83
There are 1004 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
