Yo-
I am not happy with my current CPU tempature. I am running an Athlon64 3700 socket754 with a Zalman CNPS7000 heatsink and fan. My idle temps are around 44-45C and under load it jumps to 63-64C. I have installed the CPU cooler properly, using arctic silver 5, cleaned the cooler and CPU, applied the thermal paste per instuctions using a small grain of rice for the amount and rotated the cooler over the socket to clear out any air bubbles. I am still having what I think are heat issues ( a friend told me I was crazy, that these temps are normal). AM I LOCO? I have 5 case fans, all of which are running, the case temp reaches about 32C. So is this normal or am I installing the cooler wrong? Also does anyone use the same CPU and what are your temps?
Thanks guys.
Thanks guys.
