I am trying to overclock to ATLEAST 333mhz FSB but my P5B-Deluxe will NOT post @ anything over 330, It's IDLE @ 36c and 45c LOAD @ 325.. so I doubt temperature is an issue, my ram is rated for 667, so shouldnt the ram be able to handle 333? mind you it is solid as a rock @ 325, however I want MORE!
voltage is set to 1.3125
fsb = 325x9
ignore temp = enabled (under harwdware monitor)
everything else is auto and using SPD
the cpu-information section has everything disabled.
durring post ram is shown as pc-4300, but its really pc-5300
also in CPU-Z it shows the memory @ 325mhz with a 1:1 ratio
fsb = 325x9
