i am connected to a 100mbps cable network and initially all was well as everything was running smoothly but now i get about 70 network attacks per day(LSA exploit me firewall says,to the death of me i dont know what it is) and the internet is extremely slow :cry: ,what i want to know is that is there any way to find out if my network administrator is deliberately restricting bandwidth to certain users :roll: ?
Sponsored Links
Try a couple internet speed tests to see what you get.
Make sure your computer is fully updated (virus protection, firewall, windows updates, etc)
Scan for spyware and viruses
Disable ICMP on your wan connection (if possible)
Reply to folken
- 0 +
http://rusecure.rutgers.edu/secure [...] asures.php
Read this and it'll tell you what to disable and what to do to prevent this. You may want to consider picking up a router to block those ports which would take the lag off your computer. You can also hide your WAN IP address from the outside which may help in reducing attacks. A router runs about $50.
Reply to riser
To answer you other question, there really isnt a good way to say for sure if your Admin is throttling your connection. But the speed tests will at least give you a good idea.
Reply to OmegaVTX
Tom's Hardware > Forum > General Networking > Network General Discussions > LAN woes, please help.
There are 944 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
