Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have a Dimension 4100 PIII with Windows XP Pro that has developed
several problems.
My external Iomega CD-RW burner (Drive G) no longer recognizes blank
CDs. However, I can burn CDs on this drive using Windows Media Player
but not Iomega HotBurn.
Both my factory installed D Drive (CD-Rom Lite-On LTN 483S 48xMax) and
E Drive (LG CD-RW CED 8080B) play music CDs, but can't read data CDs.
The drives blink and a disc icon flashes when I insert the data discs
but the following occurs:
D drive - Can't read data cds at all. Dialog box says "Please insert a
disc."
E drive - Dialog box with music program selection pops up as if I'd
inserted a music cd. I can't open the disc in explorer. Dialog box
says "E:\ is not accessible. Incorrect function.
I tried to do a System Restore to several different restore points,
but System Restore is not able to restore to any point in the last
week even though the system has been backed up all those days.
> several problems.
Then you need to take this up with Iomega. This isn't a Windows issue.
> disc."
Sounds like there may be a fault with the drive.
As above.
The points are corrupt. You will need to disable SR (via the SR tab in the
my computer properties) reboot and then renable it. You will lose all points
but, as they are corrupt, it's no great loss.
Facon - the artificial bacon bits you get in Pizza Hut for sprinkling
on salads.
>several problems.
>disc."
>Any suggestions will be appreciated!
Open Control Panel - System - Hardware - Device Manager and uninstall
all 3 of the problem devices. Reboot the computer and let it
redetect and reinstall the device drivers.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
"The reason computer chips are so small is computers don't eat much."
