Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have a Compaq laptop bought 18 months ago and the pre-installed version of
XP had a battery optimizer. A week ago I bought an HP laptop whose
pre-installed XP lacks the optimizer.
a) Has that feature generally been discontinued?
b) I have the XP CDs that I got with the old laptop. Could I try to install
that feature on the new machine or will that reinstall XP completely and
possibly wreak havoc?
> Thanks,
> A.
What makes you think that the battery optimizer is an XP feature and not
an OEM-added feature? If you try to install something from another OWM
disk it might violate the EULA and your warranty.
> Thanks,
> A.
Sometimes computer manufacturer's add things to a Windows setup. This is
probably the case with the "battery optimizer." Was this a program that ran
down the battery and then recharged it? Useful with the older laptop
battery types but deemed unnecessary with the newer ones.
