Help!!! New computer issues
okay, i just got about all the stuff i need for my computer.
*PSU
*MOBO
*GRAPHICS CARD
*CPU
*RAM
And now im having issues, when i first started it it ran for about 30 seconds making beeping noises, then i somehow got it to show the asus(or abit) screen then it turned off again, so i figured its becuase i didnt plug everything in (fp audio, fp usb, fp firewire, reset sw,etc..) so i figure since i forgot to install the studs for the mobo i'd do that too, so when i get to the audio pins, i see a jumper or whatever its called, so i remove it and install the plugs and get everything else hooked up. then when i plug the power cable in and push the power button, nothing happens. I look at the status led or whatever on the motherboard(it shows numbers) and its on, so i know its getting power. So i figured its the jumper, and im looking around for it and i guess i lost it so out of luck there, any ideas. btw, the board is an ABIT AA8 DURAMAX.
plz someone help me!!!
*PSU
*MOBO
*GRAPHICS CARD
*CPU
*RAM
