Wild Ideal on cooling!!: What about using a wine cooler
I just came from fry's and while there I saw wine coolers of various sizes. When looking at the instructions that came with them some are digitally regulated. They come in all different sizes and shapes, and are meant to keep the internay contents up to 30-40 degrees lower than ambient.The one I was interested in experimenting with was made by Avanti at avantiproducts.com Model number EWC12.
Internally it is 12.75D*7W*20H inches It has a glass front and locks. Maybe this could be a whole new genre of computer cases.
I am considering buying one in the near future when I have some free time and experimenting. IN the mean time I am going to call the company and see what obstacles I would face other than voiding the warranty.
42 answers Last reply
More about wild ideal cooling wine cooler
  1. this would definately not work for one reason. these coolers do not provide enough cooling power. they are designed to keep wine cool. wine does not generate heat.
    they are only designed to negate the heat that would get in through the insulation to keep the inside cool. this is not enough to keep your computer cool.
    a fridge or a freezer might have a chance, but your computer consumes enough electricity as it. this is generally just a bad idea.
    you would be better off just investing in a watercooling system, it will work much better and probably end up cheaper.
  2. When you call the company, ask them how many watts of energy the cooler can remove from it's contents in a given period of time.
    You will probably find it isn't enough to be effective at cooling a PC, chilling your water in a water loop a few degrees? Maybe. If the funds are sufficient, give it a shot! Report back.
  3. nice idea for a mod, if you can overcome the heat of the computer... hmm a wine chiller computer. I'll put that right next to my Prescott coffee maker.
  4. Actually the Prescott Coffee Man 5000 never left the design room. Apparently it boiled the coffee on contact, or it shattered the glass of the pot.
  5. I thought it set the building on fire. :?
  6. Yeah, my prescott coffee warmer notion didn't work out either. On the plus side, I have now a very nice solder bath for tinning wires...
  7. Coffee maker, psh, I need something for BBQ... maybe I get a 4 socket mobo, and then put a grill on top... mmmm BBQ... wonder if fat + electronics mix...
    One more thing about chilling to sub-ambient temps... condensation, water and electronics don't mix so you'd have to spend a ton of money and effort to combat that problem. Good try, but no dice.
  8. Quote:
    I was thinking this as well when I began reading this thread. It may still be plausible since the cooling unit of the wine cooler is probably pretty weak and would not reach 30-40F. Maybe 60F at best? Which at this temperature would not produce condensation.
    But, without trying it for real, there is no way we can determine what the actual inside temperature would be. Depends on -processor -how many drives you'll have etc etc etc.
    The other problem is the fact that the compressor in the wine cooler, like many fridges, are not designed to be operating 24/7. The temperature control on your wine cooler would constantly try and achieve at least 40F inside - while I believe this is unachievable with a motherboard cpu etc all running inside - it would burn out the motor fairly quickly I would imagine.
    And finally, I'm curiously how you plan on using optical drivers (CD-ROM etc) in this potential rig. You would need to keep a pretty tight seal for the wine cooler to effectively cool - that is if you surpassed all the prior obstables.
  9. You'd have to see if the cooler would even work at an elevated temperature. The refrigirant picked as well as the component sizing in a fridge are picked because of the thermodynamic properties at the temperature at which the system will run. Since the refrigiration system is designed for a few degrees above 0, having a steady-state heat generation system inside may not allow as much heat as you think to be rejected to the room from the computer.
    Jo
  10. Quote:
    I've got a slightly different idea: put the wine cooler where the computer case used to be. Cool wine can be appreciated sometimes. Put the computer case outside where it is presently snowing. A dog house or something should keep the snow off the case. Since the outside temp is somewhere below freezing, the Zalman should blow enough cold air across the cpu to keep it frosty cold. If enough snow falls, you could make a snowman by the case to simulate a person working beside the cold computer case. Meanwhile, you can sit in the house, nice and warm, enjoying that wine cooler while palying a game.
  11. Quote:
    Lol, this responce had me laughin my a$$ off. I agree with the people above. Sounds like more trouble than its worth.
  12. Nope. It will not work like he said. Need something more powerful.
    Like this:
    http://www.titan-cd.com/eng/heatpipe/amanda.html
    http://www.vigorgaming.com/components/cmp_monsoonii_intel.html
    or buy them expensive TEC cooling kit from Swiftech.
    Here's another wild idea.
    http://img420.imageshack.us/img420/2143/extremecoolingww9.th.jpg
  13. Quote:
    Then check this out.
    http://youtube.com/watch?v=_0QjZ6DY3xc
  14. Have you considered a Wine Cooler-Cluster.
    :lol:
  15. while i was trying to find an image i had seen a while back where someone used duct tape, 12pack soda boxes, and an air conditionery. They created a tunnel to his computer case.
    But the wonders of the internet pointed me to this ->
    http://www.nvnews.net/reviews/waffer_aircon/index.shtml
    What happened to the good old days were I would take the side off my case and prop a box fan up next to it.
  16. How about something like this?
    I wonder what the thermals on the foam would be?
  17. :lol:
    But here's a more environment friendly approach to pc cooling.
    http://forums.pcper.com/showthread.php?s=&threadid=205289
  18. Depends on if the foam is flammable or not.
  19. From the article about the foamy computer.
    It's heat resistant up to 100°C and more or less in-flammable (ie. fireproof). It's also waterproof, non conductive and -and that's really important- it's light.
    I don't buy all that though. I'm trying to look the stuff up to find out.
  20. Wow! I'd be sold if it doubled as a coffee cup holder. :D My desk is cluttered with PC hardware and assorted fasteners. It would be nice if it gathered the disapated heat to keep my coffee steaming hot.
    Here's an idea, how about using one of the WineCoolers to cool a single component like say: The hard Drives. (Probably still insufficient) but more plausible than the whole PC.
  21. HMMMMMMMMMMMMM... Fried Foods...
    Still prefer my BBQ...
    Ya'll saw the computer in oil right?
    http://www.markusleonhardt.de/en/oelbilder.html
    I think attaching an A/C unit to a comp is a better idea, but then the A/C would be heating you up... not to mention they eat up a damn lot of electricity.
  22. There are no small fridges that could withstand extracting 400-500W of heat continuously. As previously mentioned, fridges are designed to "keep things cool".... those compressors aren't meant to run continuously.
    Here's a quick test you can try. Find a big powerful fridge, and a small "Black and Decker" 110V heater. Most heaters are 1000-15000W, but at their "low" setting they are usually around 500W
    But that heater (at low setting) in the fridge, let it run and see what happens. The fridge will not be able to keep up.
    A more interesting alternative would be to use an air conditioner compressor. Coupled with the watercooler for the PC, this could be a double-cycle heat exchanger. Put the PC radiator next to the AC cold coils and using fans pull the cold air through the PC radiator.
    Also, as mentioned previously, if the PC's liquid coolant is sub-ambient you will risk condensation. the twin-cycle heat exchanger should have controls to prevent the liquid coolant to go sub-ambient towards the PC
  23. A Pentium D furnace? Or more specifically a Pentium D blast furnace?
  24. We could make a fortune on all these old Pentium D's selling for like $50.
  25. Genius!!
  26. :idea:
    Here's one I thought of some time back. A 1.9 cu ft mini freezer @ 20" square. It has a thermostat that can run the unit to -20 C. It's under 200 bucks.
    My idea was to trash the door and replace it with a triple pane, argon filled thermopane unit with the "heat mirror" film inside, (blocks most infrared transmission), set in a frame and installed with a silicone gasket held on with thumbscrews.
    Mobo set inside on plastic standoffs with ground wires at top of standoffs running to silicone sealed connectors at side or top of unit along with all other needed wires to PC case, with all other components (psu, drives, etc), mounted on side or top.
    If heat load is to great for freezer then............................
    Cpu and Gpu to have heatpipe coolers that have enough space between base and fins to allow fins to be sealed in insulated, sealed "through" duct with 120mm fans.
    Fill Port and purge valve to fill sealed freezer with nitrogen to eliminate all moisture.
    Pc should work great even with freezer unpluged. Even better turned on and set to -20 C cooling entire mobo, ram etc.
    How about one of you guys with more time and money than me build it and let me know how it works :)
    Oh ! by the way HELLO. Been a lurker here for YEARS.
  27. The best way that I have found to use wine to cool anything is by putting it in my bong to mellow the Hawaiin Red and Purple Haze and give it a nice fruity after taste. I have also found that dry red wines are better than white for taking the harsh out.
  28. Quote:
    Actually this is a good idea. My girlfriend and I were sitting in front of a nice warm Pentium D 805 @ 4.0ghz with the panel off, sipping some wine and eating chocolate covered strawberries in sensual ways.
    She got a little chilly so I just threw another Prime on Core 0 and I don't have to tell you what happened when she warmed up... :wink:
  29. Best unorthadox cooling solution... Central Vac... and keep it nice and dust free too :P
  30. Quote:
    Thats so wrong.... its right.
  31. Why thanks...I guess? How does one become a member of DaClan? My avatar would look good on that bar...
  32. Just add the user bar too your sig. The management is pretty full now but I'll get to making individual user bars later.
  33. Nice!
    Keep posting....you lurker!
  34. Quote:
    :idea:
    Too difficult.
  35. you make my prescott cry :'(
  36. One of my friends used a wine cooler as a quick fix for an overheating video card. Only a temporary fix though.
  37. How long until some Einstein applies one of these:
    Cutting Edge Cooling Technologies
    and becomes the next ultraquadillionaire?
  38. Quote:
    ROFLMAO
  39. I have a plan to one day rig up some pipes and use some plastic sheeting and plenty of silicone sealant to use water cooling on a normal heatsink... something big like a zalman flower or something... and have the tank and radiator sitting outside the window so all the heat adds to global warming... and keeps my processor nice'n'chilly.
    I noticed that with a waterblock, if you run water over it from the tap and just feel it with the back of your hand, it feels a little cool... if you take a big 'ol zalman flower and do the same... damn that gets chilly! So why don't watercooling companies use flower-type heatsinks? Some sort of fin area/watt critical threshold is crossed or something?
  40. Quote:
    Something along these lines?
    Thermaltake Volcano
    It's not a Zalman flower but more like a Big Typhoon running on water. Plug this into a system with a strong pump, a triple 120mm rad and some 2500 rpm fans and you could cool off Satan's a$$hole. :lol:
  41. i've placed an intel in epoxy, and now it's always heating my hands, and nuts :lol:
    http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&t=211088&highlight=keychain
  42. Quote:
    ...and you could cool off Satan's a$$hole. :lol:
    2nd ROFLMAO this thread! Keep it up, guys! :lol:
Heatsinks Cooling Wine Overclocking
