Wireless gear tests
HI
1st I like your site because of your tests.
I found out with building wireless networks, that the biggest problem is stability under full load or with bad packets and there is a huge difference among devices.
User with constant problems (hardware reset etc.) dont pay so much attention to transfer rates, which you tested...
I understand that testing of this kind takes a lot of time, but it will
help costumers the most (that is my opinion)
Thanks
Marko
1 answer Last reply
More about wireless gear tests
  1. Thanks, Marko.
    Unfortunately, from analyzing our web traffic, it appears that most readers don't value this information as much as you do. They appear to just want to know the "bottom line", i.e. have us tell them what to buy.
    However, feedback like yours helps us to keep doing the type of testing that we do.
    Best regards,
Wireless Hardware Devices
