Tom's Hardware > Forum > Computer Peripherals > Webcam > little problem (?)
little problem (?)
Forum Computer Peripherals : Webcam - little problem (?)
Archived from groups: alt.comp.periphs.webcam (More info?)
Hi, i have a little prob with my webcam.
My friend tell me the image was non right (the top at the bottom and the
bottom at the top), i don't know english very well & i don't know a better
way to explain.
In my check window is all ok.
Stefano B.
Sponsored Links
On Mon, 19 Jul 2004 13:03:43 GMT, "S.B." <civediamola@libero.it>
>way to explain.
>Stefano B.
Try changing your capture format. Is it RGB or someother setting?
Reply to Anonymous
> way to explain.
What camera do you have?
What software are *you* using?
What software is your *friend* using?
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
Reply to Anonymous
yes, in the settings there is only "sRGB color space profile", must i add
other ? which can i try ?
me and my friend are using netmeeting, with my brother i use messenger and i
never had problem.
Thank you for help!
Stefano
"Si Ballenger" <shb*NO*SPAM*@comporium.net> ha scritto nel messaggio
news:40fc4de0.105655514@news.comporium.net...
better
> >way to explain.
> >Stefano B.
Reply to Anonymous
On Tue, 20 Jul 2004 07:44:19 GMT, "S.B." <civediamola@libero.it>
>never had problem.
>Thank you for help!
>Stefano
Try reinstalling your cam drivers. I've seen this happen with the
Winnov VFW based drivers when WDM drivers are installed for other
cams.
Reply to Anonymous
Thank You! :)
news:40fd920d.43726845@news.comporium.net...
and i
> >never had problem.
> >Thank you for help!
> >Stefano
> cams.
Reply to Anonymous
There are 945 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
