Tom's Hardware > Forum > Computer Peripherals > Webcam > Webcam problem Philips ToUcam 820k
Forum Computer Peripherals : Webcam - Webcam problem Philips ToUcam 820k
Archived from groups: alt.comp.periphs.webcam (More info?)
My webcam won't give a normal picture. I've got to connect and
disconnect several times to get a picture. Most of the time grey,
purple / green or no picture.
On my old Pentium 2 400mhz computer it works great. My new AMD Athlon
2800+ my cam doesn't work directly.
Anybody a sollution? :cry:
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
Sponsored Links
Le 7 Aug 2004 15:11:36 -0400, ishetwelzo@hotmail-dot-com.no-spam.invalid
I have problems installing the drivers on my new PC with WINDOWS XP...
Installation worked fine on my old WINDOWS ME laptop, but now it aborts without
a word, leaving behind a file named "KILL820.exe".
Anyone else got that problem?
HELP NEEDED BADLY here...
Thx for any clue...
Jack
Reply to Anonymous
Hi,
you tried Philips for the right driver(s)?
go to:
http://www.consumer.philips.com/gl [...] le.jhtml.2
regards
Hans
> Thx for any clue...
> Jack
Reply to Anonymous
Le Tue, 10 Aug 2004 00:41:17 +0200, HansE <jerkamp@hccnet.nl> vous écriviez:
>Hi,
Yes I downloaded the last drivers....
What the hell is that "kill820.exe" program generated by install??? Anyone using
that cam got it somewhere on her PC?
Isn't it possible to install the drivers manually? (bypassing the Plug'nPlay
procedures)
>go to:
>http://www.consumer.philips.com/global/b2c/common/customercare/searchResults.jhtml;jsessionid=ZOFHLFXUUGPI5J0RMRCRX13HKFSESHAW?_DARGS=%2Fglobal%2Fb2c%2Fcommon%2Ffragments%2Fsmile.jhtml.2
>regards
>Hans
>> Thx for any clue...
>> Jack
Reply to Anonymous
might want to see if the motherboard has an updated driver set available for
its chip sets which may include the board and windows usb drivers.
<Jack.ben@laposte.net> wrote in message
news:4118bcbb.6960843@News.individual.DE...
écriviez:
> >Hi,
using
Plug'nPlay
> procedures)
> >go to:
> >regards
> >Hans
without
> >> Thx for any clue...
> >> Jack
Reply to Anonymous
Hi Jack,
I did manually.
I removed all software via start - etc and than software.
I removed the Philips software.
I download the latest software drivers for Window XP "PROFESSIONAL"
this file is an .exe file and run
Good luck
Hans
>>Hi,
> procedures)
>>go to:
>>regards
>>Hans
>>>Thx for any clue...
>>>Jack
Reply to Anonymous
Thanks Hans,
I did just that, too, but the .exe file from Philips just stops in the middle of
installation, without a word.... doesn't even ask the user to connect the cam on
USB... and leaves behind that ominous 'kill820.exe" file...
I tried to unpack the ".cab" files within the .exe file (which can be opened by
winzip)... but winzip cant unpack them... neither does WINDOWS... must be a
proprietary format...
Anyone else had those problems????
Jack
Le Tue, 10 Aug 2004 21:25:26 +0200, HansE <jerkamp@hccnet.nl> vous écriviez:
>Hi Jack,
>I did manually.
>Good luck
>Hans
>>>Hi,
>> procedures)
>>>go to:
>>>regards
>>>Hans
>>>>Thx for any clue...
>>>>Jack
Reply to Anonymous
Done all that, but no result till now. Is my processor maybe to fast
for this Philips trash?
Reply to Anonymous
- 0 +
On 14 Aug 2004 08:10:25 -0400,
> Is my processor maybe to fast for this Philips trash?
No. Did you install the driver in the right order?
Driver first and connect the camera thereafter
when the installing process tells you to do so.
This Philips cameras are very good products.
No trash.
Reply to ken
I did install the driver first. Afterwards I got a message to connect
the camera WHEN there will be asked for. It never did.
Has it something to do with USB 2.0 maybe? With my older computer, USB
1.1, it worked at once.
Reply to Anonymous
ishetwelzo@hotmail-dot-com.no-spam.invalid (webcammer) wrote in message news:<41288d7c$1_3@news.athenanews.com>...
Hi!
I have the exact problem on my new AMD 64 laptop.
Did you eventually make it work?
Reply to Anonymous
> Hi!
I have the same problem too. Philips Vcheck is missing too. An this
program normaly configure the cam.
It could be a problem with nvidia chipset or graphiccards.
If i use the broken driver, i get sometime a green picture with some
shadows.
I ask now the suport of philips and hoply they can help us.
Sven
Reply to Anonymous
There are 1233 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
