What will power dual x1950xt's???
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - What will power dual x1950xt's???
I was wondering what power supply I should buy for crossfire x1950xt's?
I was looking at this power supply and wondering if it has enough power (or may be too much) and supplies the required amperage on the 12V rails?
750 Watts:
http://www.xoxide.com/silverstone-st75f-750w-watt.html
or
650 Watts:
http://www.xoxide.com/silverstone- [...] w-psu.html
Any recommendations will be quit helpful.
Thanks.
Sponsored Links
atleast the 750 watt one maybe even more
Reply to skud
- 0 +
No.
that 650W is fine.
Reply to k-
- 0 +
I don't know much about power supplies and what not, how do you go about figuring out what amperage is needed for the graphics cards? Here are the stats for the 650 Watt ps:
http://www.silverstonetek.com/products-65zf.htm
Do you just add the two 12V rails?
Also does Silverstone make good power supplies? What is the best power supply per dollar spent? Thanks.
Reply to mryguy
PC P&C is considered the best, they are expensive though. Silverstone, Seasonic and OCZ make very good psu's at a decent price. Either of the ones you've chosen will work. You can check your requirements at http://extreme.outervision.com/psucalculator.jsp
Reply to waylander
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > What will power dual x1950xt's???
There are 942 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
