Not sure that this thread is in the right place.
Just checking if there might be someone that knows where the problem is.
Got my new graphic card today, a "Sapphire Radeon X1600PRO 512MB DDR2, AGP8X, Tv-Out, DVI-I, Lite-Retail".
I put it in the computer and installed the drivers with the cd that follows. Everything worked as it should but when I was trying a game I noticed the sound wasn´t working anymore. So I took out the soundcard to check what drivers I needed to download for it but when I turned on the computer again the screen didn´t start.
I got a message on the motherboard "FF": "The flash has been updated successfully. Make flash write disabled. Disable ATAPI hardware. Restore CPUID value back into register. Give control to F000 ROM at F000:FFF0h".
Don´t know if it should say that or if it tries to say something is wrong but as I said gthe screen wont work anyway =/.
I thought that the computer might lack power so I put the old graphic card in instead but I got the same problem, the screen wont work. So now I don´t know what to do to make it work =/
