Treo 650 compatible with new high speed 3G Cingular network?
Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
I am not very knowledgeable about the type of network that Cingular is
setting up (by end of 2006). The press doesn't provide much details either.
http://www.msnbc.msn.com/id/6622740/
Will Treo 650 work at the high speeds on this 3G network?
Aloke
to reply by e-mail remove 123 and change invalid to com
12 answers Last reply
More about treo compatible high speed cingular network
  1. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In article <Qarrd.1294$CG4.512@fe2.columbus.rr.com>,
    First off be aware that there are two different Treo 650's.
    A CDMA model for Sprint, already being sold.
    A GSM model for Cingular and T-Mobile thats not out yet.
    read:
    <http://www.palmone.com/us/products/smartphones/treo650/treo650_gsmdsheet
    ..pdf>
    and you will know as much as anyone.
  2. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    "Jack Zwick" <jzwick3@mindspring.com> wrote in message
    news:jzwick3-FB7AF1.16203301122004@news1.east.earthlink.net...
    >> either.
    I was aware of the CDMA vs. GSM versions of phones and networks. I use a
    multiband Motorola V300 with Cingular.
    I was hoping someone would know more about the 3G networks that Cingular has
    announced ..
    From John Navas's post it appears that Treo 650 won't be compatible at
    higher speeds. Isn't Treo using the EDGE technology?
    "The new network will offer average data speeds of 400 to 700 kilobits
    per second, versus 135 kilobits per second on the current EDGE
    network, and "bursts to several megabits per second on capable
    devices." ..."
    Aloke
  3. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    [POSTED TO alt.cellular.cingular - REPLY ON USENET PLEASE]
    In <Qarrd.1294$CG4.512@fe2.columbus.rr.com> on Wed, 01 Dec 2004 22:01:20 GMT,
    Only if it supports UMTS (which I'm pretty sure it doesn't).
    Best regards, HELP FOR CINGULAR GSM & SONY ERICSSON PHONES:
    John Navas <http://navasgrp.home.att.net/#Cingular>
  4. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In article <oZrrd.8794$_3.105001@typhoon.sonic.net>,
    It'll be 2 + years before the UZTMS is anywhere near widely available.
    By then we'll be at the Treo 850.
    The 650 does support EDGE.
  5. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    And Cingular barely has that.
    jer email reply - I am not a 'ten'
  6. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In <GXrrd.794$zJ.118@fe1.columbus.rr.com> on Wed, 01 Dec 2004 22:53:26 GMT,
    >announced ..
    Cingular 3G is based on UMTS -- see the press release.
    > devices." ..."
    Read that more carefully. ;-)
  7. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In <jzwick3-D43A4D.17124801122004@news1.east.earthlink.net> on Wed, 01 Dec
    UMTS is already available in the greater metro areas of Seattle, San
    Francisco, San Diego, Phoenix, Dallas, and Detroit.
  8. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In <colqtj$dk6@library2.airnews.net> on Wed, 01 Dec 2004 19:26:07 -0600, Jer
    EDGE is in fact widely deployed. See
    <http://www.cingular.com/download/GPRS_EDGE_coverage_10_28.pdf>
  9. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    Oh God, another map...! Apparently, deployed is one thing, actually
    working quite another. I have no need for wireless data at any speed,
    but a friend that does travels with me and a GC-82 often enough to
    notice when it works and when it doesn't. It doesn't most of the time.
    GPRS yes, EDGE, nada.
  10. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In <com9ol$ngk@library2.airnews.net> on Wed, 01 Dec 2004 23:39:28 -0600, Jer
    EDGE is in fact actually working as advertised.
    With the GC82, there's no direct way to tell whether it's in EDGE (actually
    EGRPS) or GRPS mode, so I assume you're making that distinction based on
    speed, but that won't necessarily be accurate, since EDGE has similar speed to
    GPRS in poorer signal conditions. In addition, the GC82 might not be
    performing its best if the firmware hasn't been updated to the latest version.
  11. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    Doesn't appear to be to my GC-82 friend.
    Well, yeah, speed, of course. Is there some other way? The firmware
    was downloaded from the SE website just a week or so ago, and I watched
    him flash it, and verify it's existence afterward. Did it seem to help?
    He didn't think so when I spoke to him last night. As far as signal
    level is concerned, the software he uses has a signal level indicator
    (a vertical series of increasingly larger bubbles which get bigger and
    coloured orange with stronger signals). That's what he, and presumably
    others, use to know about signal level - all bubbles orange = strongest
    signal. I don't recall anything that indicated how many channels are
    bonded for his connection. So, he presumes that 70-80Kb/s is the
    quality of the delivered service.
    So, we all need to understand he's not going to get wrapped around the
    axle about the technicalities of service delivery - he IS going to get
    wrapped around the axle if his data service doesn't perform as
    advertised and paid for AND he's not going to give a rat's furry butt
    about much else. He's not a cellular engineer, he doesn't understand
    (nor care) which widget has to fit the nexus on Tuesdays, Thursdays, and
    alternate Fridays, he's using the Cingular service with Cingular
    equipment according to Cingular's instructions. That's all he cares
    about, and that's all he should care about - anything else is
    superfluous and unecessary. Since it's his service, his equipment, his
    job, and his time being paid for by his pocketbook, only his opinion
    matters.
    Now, is there anything else about this situation that you need to be
    confused about?
  12. Archived from groups: alt.cellular.cingular,comp.sys.palmtops.pilot (More info?)
    In <con813$ho0@library2.airnews.net> on Thu, 02 Dec 2004 08:16:00 -0600, Jer
    Does for me and others. Perhaps your friend has a defective card, downlevel
    firmware, or is working in poor signal areas.
    Yes, with the proper tools.
    >The firmware
    So previously the firmware was downlevel.
    But then it's only been a week.
    >As far as signal
    Sounds like Cingular software. He might get better results with the latest
    Sony Ericsson Wireless Manager. (That's what I use.)
    >signal.
    There are better ways to read the signal from the card; e.g., FMA, which will
    display the actual percentage of signal.
    The number of timeslots (not channels) can only be known with certainty with
    the proper tools; otherwise it can only be inferred.
    If measured accurately (a big if) and if the computer is configured properly
    (another big if), that suggests EGPRS (EDGE) rather than GPRS and a relatively
    weak signal. In my own tests of Cingular EDGE with very good signal, the GC82
    consistently achieved 130/180 Kbps on downlink (depending on timeslots, 2 or
    3), and 120 Kbps on uplink (2 timeslots). With only good signal, downlink was
    100-110 Kbps.
    He's getting what was advertised and paid for -- top performance isn't
    guaranteed in all cases.
    >matters.
    With that attitude he's not likely to get the best performance. His choice.
    >confused about?
    It's not me that's confused. ;-)
Cingular Compatibility Treo Internet Service Providers
