Tom's Hardware > Forum > Wireless Networking > Range & connectivity > adding a wireless router to a wireless hub
Forum Wireless Networking : Range & connectivity - adding a wireless router to a wireless hub
How do i add a wireless router to a wireless hub. My signel strenth to my sound bridge which is 2 floors away is weak , so i thourgt if i add my old wireless router it would improve things. Would it mater if 2 signels were getting through,the sound bridge is a roku m100. thanks
Sponsored Links
I have no idea what a sound bridge is, but if you're having signal issues, then the best solution is to add a second access point. (I assume by wireless hub you mean an AP). If you disable DHCP on your wireless router and connect it to your network using one of the LAN ports, then it can function as an AP as well. However, this requires a physical connection to the network somewhere near you for the router to plug in to. There are a few wireless repeater products out there that might work, but I have zero experience with them. Google is probably your best friend for info on them.
Reply to FredWeston
There are 478 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
