Lo all, these are the new parts I should be getting for my PC I was hoping you guys could look over them and see if they're all good/compatible or if something needs changing, cheers.
(PC is used for mainly gaming)
500W AKASA Ultra quiet Active PFC ATX 2.2 PSU with Black 12cm Fan £55.05
2Gb (2X1Gb) Corsair Value Select, DDR2 PC4200 (533), 240 Pin, Non-ECC Unbuffered, CAS 4-4-4-12 £136.79
Intel Core 2 Duo E6400, Socket 775, 2.13 GHz, 1066MHz FSB, Allendale Core, 2MB Cache, Retail £144.35
160 Gb Western Digital WD1600JS Caviar SE, SATA300, 7200 rpm, 8MB Cache, 8.9 ms £37.59
256MB Gainward 7950GT Bliss GS PCI-E (x16) Mem 1500MHz GPU 580MHz 24Pipes Dual DVI/S-Video SLI £183.05
Asrock ConroeXFire-eSATA2 (Socket 775) PCI-Express DDR2 Motherboard £58.74
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black £57.56
