Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Help on peer to peer network with a wireless router
Forum General Networking : General Gateways, Routers and Firewalls - Help on peer to peer network with a wireless router
To make a long story short, I have a cable modem with roadrunner online service. The connect used to be fast and flawless until I purchased a wireless router. I had to get one because my apartment does not have a cable outlet in the bedroom where my computer is, nor will anybody install one. I have a belkin G card in my pc and a belkin brand router. I can surf wirelessly all day long at pretty fast speeds, but when I want to download something from a peer to peer network, my connection keeps "choking out" with the number of hosts and downloads. Is this caused by the wireless router, or do I have to change settings to handle this, anyone's help would be greatly appreciated. 8O
Sponsored Links
I would get a long enough cat 5 cable and just run it to the computer. Wireless is always slower than wired. Just snake the cable along the baseboards to the room.
Reply to sturm
- 0 +
Depending on what p2p software you use you may need to forward some ports to get the most out of your bandwidth.
Just out of curiosity what router did you get? Not all routers are made equal, it may be getting more load than it can handle. P2P puts more load on a router than anything else.
Reply to folken
I got the run of the mill belkin wireless g from wal-mart. I think I will just run some ethernet cable to my modem and throw the router in the trash. Wireless sucks for my application, thanks for the input anyhow
Reply to johnnywadd
- 0 +
Yea, in my experience belkin had about the worst home routers money could buy. It is no surprise to me p2p was killin it. If you spend a bit more and get a higher end linksys or buisnessline netgear (blue metal) they should handle it much better.
Reply to folken
There are 585 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
