Please help with system build!
Right now I have a Radeon X1900XTX 512MB PCI Express x16 card. I would like to get a Intel Core 2 Duo E6600 2.4GHz LGA 775 Conroe 2.4GHz 4M sharing L2 Cache Processor.
The issue is I never owned anything from intel, have no clue on set up or much of anything else on this. The main questions I have are.
1. (stupid one) will my Radeon X1900XTX card work in any MB with an Intel Core 2 Duo E6600 in it? Also if the MB has 2 PCI Express x16 slots can I use just one, or do both have to be used.
2. What kind of board should I get? Not a ton of money to spend (looking to spend apx $100-$160 on MB alone), I need something like this.
-Must have at least 1 PCI Express x16 slot
-Support the Core 2 Duo E6600 2.4GHz LGA 775
-NO OB video ( Hate OB video)
-Support DDR2 667/533 (to save money if possible get ddr 400)
-Maximum Memory supported must be at least 4GB
3.What kind of memory should I get (still need to save some money)
I know this is long and drawn out, but any help would be appreciated!
