Hey all, and thanks in advance
I'm upgrading my current computer to a core 2 duo system, so I need to replace the CPU, motherboard and ram.
I will be reusing everything else at this point:
PSU: Antec NEO HE 550W
GPU: Asus EN7800GT 256Mb
HDD: SATA (300Gb) SATA2 (80Gb)
Other: got a floppy, DVD etc.
Needed:
Motherboard: Looking at the eVGA nForce 680i SLI 775 Mainboard
CPU: Core 2 Duo E6600
The hardest part I am having is selecting the best ram. I live in Japan, and ram (especially high end ram) is WAY overpriced compared to the U.S.
For example Corsair TWIN2X2048-6400C4 is 44,000 yen (that's about $380 US and it is currently $250 on newegg). Same is true of all namebrand ram (Kingston etc.)
This pretty much puts the high end ram into the insanely expensive in my books, I am forced to look at the cheap stuff.
So, which should I get? These are
240PIN DDR2 PC6400-1GB(DDR800) JEDEC x2 sticks: $280
240PIN DDR2 PC5300-1GB(DDR667) JEDEC x2 sticks: $200
240PIN DDR2 PC5300-1GB(DDR667) x2 sticks: $200
240PIN DDR2 PC4300-1GB(DDR533) OEM x2 sticks: $190
240PIN DDR2 DDR2 PC4300-1GB(DDR533) HYNIX original x2 sticks: $240
240PIN DDR2 PC4300-1GB(DDR533) JEDECx2 sticks: $200
240PIN UMAX Castor LoDDR2-1G-800 (PC6400-1GB CL5) x2: $280
These are the options and prices at one of Tokyo's most well known enthusiast parts suppliers (unfortunately).
So, I mainly need help in selecting the ram. My priority is performance / dollar. Corsair is just too expensive in Japan.
I also am looking for feedback on the motherboard.
Needed:
