Tom's Hardware > Forum > CPU & Components > Other Components > Lines on my LCD Monitor. Please Help!
Forum CPU & Components : Other Components - Lines on my LCD Monitor. Please Help!
Hi,
I have the following setup:
6800gt on a 19" samsung 930bf monitor.
Sometimes, which is quite often now when I swith my pc on a blue or purple line or both appear vertically on the screen. I checked the cabling and the monitor is plugged in fine. If I switch the pc off and restart the lines go away, but then reappear sometimes when I swith the pc on.
Its not just in windows. but the lines appear as soon as the pc starts up.
What do I do! Is my graphics card broken .......
Sponsored Links
No Oc at all. I just changed my case to a smaller one thats all.
The card and monitor are about 7 months old!
Got no warranty though......
Reply to Sticky
Quote :
That's usually a sign that the LCD monitor is dying especially since you are not OC'ing your video card. But double check your video card anyway.
Reply to jaguarskx
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
