Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Help to choose a mid VGA card
Forum Graphics & Displays : Graphics Cards Help to choose a mid VGA card
Hi guys. I need your help to decide which card to buy. Nowadays I have no much bucks to buy a good one due to I decided to upgrade my old Ti4800 and replace my 753DFX to LCD 19".
VGA cards options (AGP):
XFX GeForce 6800 XT 256MB DDR3 AGP (PV-T42K-VDE3)
Inno3D GeForce 7600 GS 7600GS 256MB
Sapphire Radeon X800GT 256MB V/D/VO (1024-7D61 -01-SA)
With one would be the choice to me?
Reply to Storch
Those arent midrange cards, they're on the middle of the low end(seriously).
7600GS would be my pick.
Reply to GeneticWeapon
- 0 +
The fastest is the X800GT. It's a tough call because this card while faster will also get outdated faster as it doesn't fully support the actual DX9.0c standard. (it's a 9.0b -SM2.0 only card) The 7600GS is not as powerful, but it's fully DX9.0c-compliant. So it depends how long you want to continue with this configuration. If you just want the card to play actual games as best as possible, get the X800. If you want to try the new games when they come out, get the 7600GS.
Check out if you can't find any X800XL or X850Pro, they're faster. Also the X1650Pro is slightly better than the 7600GS, if you can find it.
Reply to Dr_asik
Check your power supply spec's before considering a replacement AGP card, because your PSU may be a limiting factor. The X850 Pro is a faster card, and some of them can be unlocked to 16 pipes, however the 7600 is more power efficient, doesn't require an additional 4 pin molex power connector, and is also a good performer.
Reply to CompuTronix
- 0 +
Thanx you guys for replies.
Talkink about PSU. Do you know if my 7team ST420BKV would be abble to support those cards?
Reply to Storch
7600 gs.. if you can crank out a few more bucks, the GT oc from bfg would definately be the ultimate pick. at least the US prices seem to be fairly low for this card.
Reply to thegreat1
- 0 +
Lets talk about power consumption graphics cards. I found this links that can help in this issue.
Faster, Quieter, Lower: Power Consumption and Noise Level of Contemporary Graphics Cards
http://www.xbitlabs.com/articles/v [...] noise.html
The Grand Clash for Watts: Power Consumption of Modern Graphics Cards
http://www.xbitlabs.com/articles/v [...] n2006.html
After check that graphics I realised the 7600GS is a good choice to me, considering my PSU, Direct X 9c, ...
But a new question. Is this new graphic cards run old games? I love Warbirds 2.77, does anyone here have played it with new cards?
Reply to Storch
With a 19" LCD you're going to probably have a native resolution of 1280x1024. That's kinda high for those cards. See if you can put a few more bucks into your card. Look for high framerate over features, because honestly at this range you're going to be stretching to play newer games on that monitor. Ebay is a pretty good source of x8** agp cards in the low $100s. Be careful buying new, though, as agp is currently industry code for "awfully grotesque prices". I'm talking sometimes 70% more than the same PCI-E card. You could get a new motherboard and a PCI-E 7600GT for less than just an agp 7600GT, which is exactly what I would recommend, really :D I didn't notice your PSU power, so you'd want to calculate that, of course. There are some handy stickies over in the PSU section.
Reply to angminas
Apparently your PSU is 420w, so it shouldn't be a limiting factor for those cards.
Nobody said it, so I will. AGP is dead. Upgrade your computer! :-)
Reply to RyanMicah
There are 1843 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
7970 vs 670
By yougotjaked, 1 hour ago:
I do video/photo editing and 3D modeling and I haven't had any problems. You could wait...
Best offers
Top experts
