Hey there. this is my first time building a computer ( in fact first time installing any part on a PC) and i am doin good so far got everything hooked up accept im stuck on how to hook my Fans up that came with my case.
I got a Centurion 5 Case and a Gigabyte DS3 Motherboard. i got all the other jumper and f panel pins in the right place. and there is a spot on my MB for "SYS FAN" with a 4 pin connecter but the fans inside the case are not. i assume i connect the 2 fans together then i would connect 1 plug in that spot but nothing is matching up.
anybody with similar build or anybody experienced know what i am talking about?
thanks in advance.
thanks in advance.
