Tom's Hardware > Forum > General Networking > Network General Discussions > Advent laptop connecting to wireless - Help!
Forum General Networking : Network General Discussions - Advent laptop connecting to wireless - Help!
Hi hope someone can give me some advice :
I recently purchased a Advent 7012 Laptop (with all my savings from my pocket money!) and would like to connect to wireless but the laptop does not have a slot for a WiFi card and when I try to connect my wireless adaptor (with USB cable) I've now discovered the USB port is not fast enough. I guess its USB 1 and not USB2. Is it possible to get a 'plug-in' upgrade or somehow get round this problem.
I'm not up on computer terminology so please reply in simple language.
Thank you!!!!!!!! :(
Sponsored Links
USB1 should be plenty fast for a wireless connection. If you are having trouble with it the problem might be that not enough power is going to the port. If that laptop has a PCMCIA slot I would get a wireless card for that, they are actually very good. It is also known as the PC card slot.
Reply to folken
There are 1308 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
