Archived from groups: microsoft.public.windowsxp.basics (
More info?)
My computer is a desktop. I went and looked and there is a program there
that is windvd creator, I just loaded that program. I don't know why it
would be there. Is there a way of getting it out of power options. Thanks
for the fast reply.
"Bill Martin -- (Remove NOSPAM from address)" <wylie@earthNOSPAMlink.net>
wrote in message news:%23o7uqfM9EHA.2600@TK2MSFTNGP09.phx.gbl...
> Rick & Deb wrote:
>> I'm running xp home sp2. For some reason in power options properties all
>> the settings are going to never. Is there a program that is causing this.
>> Thanks for all help in this matter.
> 1) Is this a new problem? Did it work properly earlier and if so, what
> have you changed? What new software was installed, etc.?
> 2) Is this a desk or laptop? On my Toshiba laptop, for example, Toshiba
> supplied their own software to tweak the power settings with -- you're not
> supposed to use the XP controls for it. Conceivably if you have some
> similar setup, then the software you're supposed to use might keep over
> riding XP's setting.
> Bill
