Archived from groups: alt.comp.periphs.webcam (
More info?)
Tnx Robert
All I get are the black squares. THe properties of the black squares refers
back to my webpage address. When I open the main webpage from the file menu
in Watcher everything displays fine. I had to change the main page upload to
index as that is what my comcast requires to view the page. I think it is
something in there. Thanks for the response. It is a great program when it
runs as I can see on the "view main page" from the file menu. Now if I can
only get mine to work as well. It is uploading to my ftp server but I don't
see any snapshot files, there are only a couple of avi's and the black jpgs.
Shouldn't there be a bunch of snapshot jpg's?
Thanks Much, David
"Robert J Batina" <rbatina@columbus.rr.com> wrote in message
news:hxLfd.2767$EO3.1224@fe1.columbus.rr.com...
> David Gerard <nospamdavid@comcast.net> spewed:
>> Have loaded Home Watcher v2 and it uploads fine but when I go to view
>> it I can't see any of the pictures, they won't load. The properties
>> on each image refer back to the files on the upload data but they
>> won't visualize...Any suggestions...Thanks, David
> Are you getting the "X" broken image thing, or black spaces where the pics
> should be, or what? I've not had that problem myself, so I can't exactly
> picture what the problem is that you're describing.
Also, are you
> using one of the default templates, or have you dinked around with the
> code
> a bit, to make it your own design? I love the proggy, so despite not
> really
> knowing anything about the inner workings - I wanna help.
The only
> time it got wonky on me was when I was adding a lot of my own javascript
> onto the cam page, and it must have borked something. heh
> You can click on the link below to view my cam page... mebbe if you view
> the source it'll help you notice something that you've been missing.
> Good luck.
> The Toe Pages:
http://www.rubbertoe.com
