I’m planning to build the following PC for multitrack audio recording (Cubase), no gaming at all:
Cabinet: Antec P150
Motherboard: ASUS P5B-E
CPU: Intel Core 2 Duo E6600
RAM: OCZ Platinum DDR2 PC2-6400 2x1024 (Dual Channel)
HD: 2 x Western Digital 320GB (Raid)
GPU: ASUS EN7300LE TOP/HTD/256M
DVD: NEC AD-7173 DVD±RW
Other: 2 x Zelman ZM-F2(92mm) with revoltec fan vibration silencers
I’m not rich, but willing to spend the necessary for the “best buy”.
The most important things are:
- Stability
- Noiselessness
Here are some of my thoughts about the components:
- Cabinet (Antec P150) (2 x Zelman 92mm fans)
I’ve chosen the most soundproof Antec (I think), but which 92mm fans are the best (quietest, but still with good CFM)?
Will the ASUS motherboard control fan speed (except the 120mm that’s shipped with the cab), or do I need special fans?
- Motherboard (ASUS P5B-E)
I need 3 PCI-slots for my soundcards, and as many PCIe for future expansion as possible.
I’d like a RAID-compatible motherboard, because with multitrack recording, I’m gonna max out read capacity on a single disc.
I’ve also been looking at Intel DG965WH because it's cheaper, which one is best (most stable)?
Intel only supports 1.8 V for the memory, ASUS supporting 2.1 V (I think, haven’t been able to find much info on this one). Isn’t 2.1 V needed for fast speed memory?
- Memory (OCZ Platinum 2x1024)
The Intel 965 chipset (which also the ASUS are build on) only supports 5-5-5-12 or slower @ 800MHz, but 4-4-4-12 @ 667MHz. (But I haven't found any alternatives that fulfil my other demands)
- OCZ Platinum DDR2 PC2-6400 2x1024 is 800MHz 4-5-4-15, at 385 US$ (Danish price)
- Kingston HyperX PC2-6000 2x1024 is 750MHz 4-4-4-12, at 338 US$ (Danish price)
- Corsair Twin2X PC2-5400C4 2x1024MB is 675MHz 4-4-4-12, at 365 US$ (Danish price)
Which memory will give the best performance, and are there other candidates?
- Overclocking
Since stability is mandatory, I’m not planning on OC, but with no experience in OC at all, I’d like some comments on this prejudice. If stability isn’t compromised, I’ll maybe OC.
- CPU cooler
Is the Intel stock cooler quiet enough, or are there better alternatives (at reasonable price)?
I'm going to use the PC for 'out of the house' recordings so it's not good with a heavy cooler that can break something by the transport.
- GPU (ASUS 7300LE)
Not chosen for gaming, but still supporting 2 monitors, it was the cheapest GPU I could find that doesn’t use the system memory (too). Does turbocache/xxx decrease memory performance?
Is it ready for Vista? On nVidia’s site, they write that 7300LE is Vista-ready, but my local supplier says otherwise.
- DVD±RW drive (NEC AD-7173)
I’ve chosen the cheapest drive I could find that supports LightScribe like technology. That’s not a must, more important is the quality of the writing.
Is there any difference (except speed) between brands/drives?
- PSU (NeoHE 430W)
Shipped with Antec P150 comes a NeoHE 430W power supply. Is it enough, or should I replace it, still considering noiselessness (module cabling is pretty neat, right?)?
If i shall have another PSU I will just buy the Antec Solo cabinet instead (isn't it the same just without the PSU?)
Advice or comments outside my specific questions is, of course, more than welcome.
/Asger
Cabinet: Antec P150
- Stability
- Noiselessness
- Overclocking
- CPU cooler
- GPU (ASUS 7300LE)
- PSU (NeoHE 430W)
/Asger
