Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > I need help choosing a graphics card, plz help
Forum Graphic & Displays : Graphics Cards - I need help choosing a graphics card, plz help
Hi,
im looking for a gfx card around thee £100 mark that will play games such as
LOTR battle of Middle Earth II, Warhammer 40,000 Dark Cursade, Medieval Total war 2, Half life 2: Ep 1, Age Of empires, Company of heros and Elder scrols oblivion
at a good level, and games of 2007 at a mid to good level. Also if possible a card that does not run to hot.
Also it must be quite small as i am in a small micro atx case and there is a nice big Antec System exteractor that keeps verything at 25 degrees even when using games. The extractor takes up 2 PCI Ports but there is room for a quite thin gfx card.
The mobo is Asus M2N-VM-DM micro atx case, i have s duel core amd x2 4200 and on 1gb ram.
The GFX Interface is PCI-e and i am in the UK.
Can anybody helo me with a good gfx card to get please thanks
Sponsored Links
I'm afraid that this is the best you can do for 100 pounds.
Asus GF7600GT 256DDR3 PCI-E 108BPS w/VAT 12/10/06
http://www.ebuyer.com/UK/product/111198/rb/23658189933
Club3D GF7600GT 256DDR3 PCI-E 102BPS 12/10/06
http://www.komplett.co.uk/k/ki.asp?sku=318805
These are good cards, just don't expect the world of them.
Reply to Newf
- 0 +
i was also thinking of the 7600, will it work at a mid level till 2008? i mean im a guy who still belives the 6600gt is good enough for this year lol
Reply to TurkzZ
Quote :
Well, I would say it won't kat until '08 if you want to play new games.
During '07 you'll see quad-cores, Vista, R600 along with 8900s.
It'll probably run UT07 and Crysis at the lowest possible settings, and pretty low resolution.
Reply to prozac26
- 0 +
i wnt play unreal but Cyrsis i will, would it really stuggle that much wit it, wouldent it even produce playable frame rate, ok gfx and reolution of 1024x756
Reply to TurkzZ
It might struggle.
At lowest settings, framerates should be playable.
Reply to prozac26
- 0 +
when is the game released,
Reply to TurkzZ
- 0 +
i was looking into 7600gt, now i found a inno 7600gt for £75 and a asus for £108.
is ther a diference between the two
Reply to TurkzZ
- 0 +
also,
there is a 128mb and a 256mb version, what are the differences
Reply to TurkzZ
- 0 +
Pref. 256mb for current games. 128 is a bit short now at days. Didn't know they still made the 128mb v.
Reply to blacken
- 0 +
If yoiu are using AGP then I agree with the 7600GT, great card for the money.
If using PCI-Express then I recommend you get a 7900GS, priced between £100 and £120 for 256MB/450/1320.
Get on ebay aqnd find yerself a deal...
Reply to MrSiko
- 0 +
i am using PCI-Express
so the 7900gs is better then 7600gt, and what do you mean by 256/450/1320
Reply to TurkzZ
- 0 +
Yeah sorry I was being a little vague there.
I meant 256 = memory, 450 = core (gpu) speed, 1320 = memory speed
Those are stock speeds for the 7900GS.
However some companies are prepared to up the clocks out of the box, such as the Gainward Bliss at Scan : http://www.scan.co.uk/Products/Pro [...] tID=476782
And only costs £105... for Overclocked speeds of 500+ on gpu and 1400+ on memory...
Will acheive great FPS in latest games and high details and resolutions.
Good luck with your purchase...
Reply to MrSiko
- 0 +
sounds great, and is this card significantly better then the 7600gt and will it play cysis
Reply to TurkzZ
- 0 +
2nd the 7900GS. Good overclocker + price/performance ratio.
Reply to blacken
- 0 +
Yeah go for the 7900GS, beats the 7600GT by quite a large margin.
Reply to sprite
- 0 +
Yes the 7900GS is much better than the 7600GT especially I guess since the 7600GT has 128 memory interface while the 7900GS has 256mb
Reply to yas
- 0 +
Dude :D
For 107.088 GBP you can get the Sapphire Ultimate X1950 PRO here:
Ultimate X1950PRO Check iit out compared to the 7600 :D
Reply to ecosoft
- 0 +
yeah that is definately better but thats $210 not £110. The x1950pro is better than the 7900GS but slightly more expensive.
Reply to yas
- 0 +
i think the 7900gs is a good one for me,
just a few questions on it:
1. how would it play the game Crysis
2. Will it work with DX10
3. Would it play games at a mid level until 2008
4.would it work with vista
Reply to TurkzZ
- 0 +
YAS Dude :D
Ya' need to learn about currency conversion ... GBP (Great Britain Pounds to USD, U.S. $) Currency Converter
The Brit TurkzZ specified "around £100", well $210 = 107.088 GBP, so that's close enough for better bang for da' buck, don't ya' think? :)
Reply to ecosoft
- 0 +
ok now im getting confused loool, so the 7900gs and the x1950 are simular priced,
which of the two is the better
Reply to TurkzZ
- 0 +
TurkzZ :D
You are asking "tech" questions on a tech forum, so here's an opportunity for you to learn how to become "more" techie yourself. Ya' need to learn how to use "trusted" review sources, like Tom's hdwe reviews, etc., etc. Here's a site that allows comparing any two vid cards both by tech (ATI, Nvidia, Voodoo, etc.) and manufacturer. Summary-Ultimate X1950 PRO
Remember here that the Sapphire Ultimate X1950 PRO version is superior to the ATI reference card performance specs, but this link gives the side-by-side specs of the ATI vs Nvidia 7900 GS: 7900 GS vs Radeon X1950 PRO
If, after reading the above you still decide to glom a 7900 GS, then I have a bridge I'll sell ya' cheap :lol:
Reply to ecosoft
- 0 +
I was able to squeeze 25 - 28fps at a 110 to 140fps thresh-hold out of a Foxconn7900GS oc'ed at 575/815 blowing by the 7900GT's advancement of 8 - 12fps over the GS at stock. 8O 13 - 16fps over the GT.
The 1950Pro advances the 7900GS by 9 - 15fps at stock. Pulling off 25fps puts it on par and further with the Pro. Selling at 40 bucks less than the Pro. Yet at high resolutions, most ATI cards whip out a few more guns.
And if you give me your name, address and number, I have a vacume you may be interested in :twisted:
Reply to blacken
- 0 +
ok looking at those comparisons it seems the 1950xt pro has better specs on everything (core clock ect)
so im guessing the 1950 is better,
but on the review the 7900gs and 1950xt pro get the same overall score
Reply to TurkzZ
- 0 +
ok after a search on the net im down to these two:
1. Gainward 7900GS £105
2. Asus Radeon X1950Pro £125
http://www.scan.co.uk/Products/Pro [...] tID=492010
which one? lol
Edit
after looking into both it seems the ATI one has a slightly higher clock speed and has 32 piplines instead of 20 so im guessing the more piplines the better?.
Is the performance difference worth the £20
Edit again
the ATI also has 36 month warrenty while 7900 only has 12 month.
Reply to TurkzZ
- 0 +
Ok it seems the 1950xt Pro is the better one and i have found at simular prices.
now there is an ASUS one and a Saphia one, thre around the same pricem, which one shall i go for?
1. SAPPHIRE Radeon X1950 Pro
http://www.dabs.com/productview.as [...] 2#infoarea
2. ASUS Radeon X1950 Pro
which one?
Reply to TurkzZ
Quote :
Yes the 7900GS is much better than the 7600GT especially I guess since the 7600GT has 128 :? (bits)memory interface while the 7900GS has 256mb 8O
You mean 7600 = 128 bits mem interface.
7900 = 256 bits " " .
Reply to killmess
- 0 +
TurkzZ Dude :)
Time to take your cupped hand away from your ear and stop shouting "somebody tell me what to do!" ... wake UP Dude! Use your reading ability to compare the specs I pointed out (remembering that I said the Sapphire Ultimate specs exceed the ATI reference specs): Ultimate X1950 Pro core clock = 580 MHz Nvidia 7900 GS = 480 MHz; Ultimate X1950 Pro mem = 1600 MHz Nvidia 7900 GS = 1400 MHz, pixel shaders Ultimate X1950 Pro = 36 Nvidia 7900 GS = 20 and, in addition the Sapphire Ultimate employs the super nifty and efficient Zalman Cooler! I gotta ask you Dude, are you unable to add 1+1 and come up with 2, or what? Can't you SEE the huge difference before your very eyes? You are obviously not even paying attention to the reviews you read ... the review that you cited compared a 7900 GS to an ATI X1950 PRO, NOT the Sapphire Ultimate version! Do ya' "get it" now? :roll:
Reply to ecosoft
- 0 +
kk still confused but i think i gathered that the 1950xt pro is the better card loool.
Shall i get the one saphier make or ASUS, there simular priced.
Reply to TurkzZ
- 0 +
Quote :
YAS Dude :D
Currency conversion works great if you are buying overseas. For UK vendors, the pricing is not the same as just taking the lowest US price in dollars and converting it to pounds.
UK Vendors:
HIS ATI X1950Pro 256 152.74BPS 12/15/06
http://www.overclockers.co.uk/show [...] =GX-065-HT
Sapphire ATI X1950Pro 512 172.71BPS 12/15/06
http://www.overclockers.co.uk/show [...] =GX-137-SP
BFG 7900GS 256 143.34BPS 12/15/06
http://www.overclockers.co.uk/show [...] =GX-033-BG
GECube X1950Pro 256 169.48BPS 12/15/06
http://www.ebuyer.com/UK/product/119300
Yes, the cards you mention are faster than a 7600GT...
Reply to Newf
- 0 +
Could somebody answer simply,
1. Is the 1950x Pro (Saphhire one - not ultimate edition) better then the 7900gs
2. will it play cysis at mid level
3. And is £110 (inc VAT) a good uk price
Reply to TurkzZ
There are 957 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
