Tom's Hardware > Forum > CPU & Components > CPUs > e6400 extreme temperature spike
Forum CPU & Components : CPUs - e6400 extreme temperature spike
I recently built this system (my first) and I while using it very lightly, the computer shut down. I checked the core temp log and the temperature had steadily climbed to 83 and then suddenly jumped to 127 celsius! Over the next 7 minutes the temperature declined steadily to 100 degrees celsius before the shutting down. The system is not overclocked at all. I have since disabled smart fan so it's always running full speed and turned the temp alarm to sound at 60. Last night, the second core reached 60.
Two questions:
1) Is it likely my CPU was damaged on the first spike? Is there any way to determine for sure if it was so I can decide to RMA or not?
2) Any guesses on why the temps have spiked and what I can do to stop this? My temps are great at all other times (hovers from 35-40).
Sponsored Links
Just out of no reason the cpu temp spiked up like that? Weird.. Im using the same cpu as you and the temp I see is always 29 celcius. The hottest Ive ever seen it was after about 2 hours of playing Supreme commander the CPU was at 37 degrees celcius.
How do you know what the individual core temperatures are ??
what are the voltages being displayed by the bios?
Reply to thegreat1
I have Core Temp and SpeedFan running. Both show the temperature of each core. Speedfan temps usually show a little lower, but not as low as 29. I'm using stock fan and I did put Arctic Silver on w/o removing the stock thermal pad, but I wouldn't think that would cause that much of a problem. My CPU voltage is 1.31 and memory at 1.8, FSB 266 with 8x multiplier (from EasyTune).
Reply to sejjiin
AS5 AND the stock paste? Not a good idea. Take the heatsink off, clean it and the CPU and reaply AS5 (better yet, get a better HSF).
Reply to MAK-Daddy32
127C... holy sh*t. I usually advise 65 to 70C with 80 being the absolute max, but 127C?... RMA it if possible, because it might start showing problems soon.
Reply to dasickninja
Did they remover thermal throttling out of these cpu's? I know with a Pentium D you couldn't burn it up, at least from my experience. If the CPU was to hot, it should have turned itself down shouldn't it?
Mak-Daddy is correct though, if you applied artic silver 5 to the stock thermal pad, that was a mistake.
However, I would think the CPU might become intermitant with that kind of heat spike, I would RMA like Ninja said, I don't think I would trust that componet anymore.
wes
Reply to weskurtz81
I loaded "optimal" settings in the bios, which I guess include turning off the temp alarm...don't know why. Thanks for the advice, I will try to RMA.
Reply to sejjiin
Try cleaning the Heatsink and CPU of thermal compound, make sure the socket is clean.
I had wacky readings, cleaned it up and now fine - it could be some thermal compound in/on the sensor messing it up - I don't quite know, but it worked for me.
Reply to DennyCraneBL
I doubt that the paste is making a difference considering how it was running at normal and then just spiked up. Though I dont see the logic of applying that paste in the first place, as the paste that is already on the fan is probably better then what you put on there.
Could be many reasons. Maybe you damaged it with static electricity. Maybe the mother board is defective. Maybe your power supply is messed up. Maybe the the sensor is not reporting the correct temperatures.
---edit-
post above me says that after he cleaned it up it worked fine.. You probably got paste on the sensor so its going nuts as soon as the cpu temp heats up.
Reply to thegreat1
I am just curious where is the CPU temp sensor? Is it under the socket? On the motherboard next to the socket?
Also, too much thermal paste is a really bad thing. First of all, he didn't say how much he added. And since he already made the mistake of adding thermal paste to the stock heatsink thermal pad, whos to say he didn't squeeze the entire small tube out. The HSF will not seat well if there are gobs of paste AND a stock thermal pad.
wes
Reply to weskurtz81
Thermal paste is used as a medium of transfer between the processors IHS and the Heat Sink, but too much of it will actually act as an insulator, keeping the heat in. That is why you should never have too much paste, or too little paste.
Reply to bigsby
Quote :
I keep hoping that someone will someday rework the Arctic Silver install instructions as a variation on Goldilocks and the Three Bears. It's just a dream I have ... :)
-john
Reply to zjohnr
Added about a grain of rice size, not much. I tried cleaning it off and reapplying, but so far temps are up to 46 idle, ugh. Maybe I hooked the fan up wrong.
I have no idea where the heat sensor is...
EDITED: I meant 46 idle, not 42.
Reply to sejjiin
I never do that grain of rice thing, I dont trust the paste to spread out evenly on its own so I do it myself. I spread AS5 over the entire IHS surface using a piece of plastic with a straight edge. Keep scraping away until I make it as thin and even as possible without exposing the surface.
Reply to randomizer
When I first cleaned off the processor, there was some spillage; perhaps that was what happened. After graphing the temps from the Core Temp log, I doubt the temps were accurate. It literally jumped from 83 C to 127 C in 1 second flat. That's an instant jump of 80 F and I would think that would only be possible with some sort of bomb.
I reapplied again and reset the fan and I now get about 40 C idle with core temp and 65 after 20 minutes 100% load using TAT, which I believe to be about normal.
Reply to sejjiin
I can only see that kind of jump if you had the cpu on 100% load with no HS or fan, which I doubt your dumb enough to try :wink: Those current temps are a bit higher than what mine are with my e6600 stock, but if youre using AS5 then your temps will drop over time. Mine started at 52C idle and 63C load and have gone to 38C (although its a pretty cool day today so probably about 40C normally) idle and mid-high 50s under full load
Reply to randomizer
Yea and even if I did go with no HS or fan, the increase would have been gradual, not an instantaneous jump. I'm pretty convinced it was a a temp read error, or at least partly. I still don't see how thermal compound could have messed with the sensor though since supposedly core temp reads the thermometer that is within the die (or so I hear).
As far as temps, they're already dropping down to around 35 idle / light load, which sounds pretty good to me.
Reply to sejjiin
Those temps are much nicer. I remember the first time I installed the HS after I got my e6600 the temp was >70C in the BIOS! A quick reseat and a replacement of the stock compound with AS5 fixed that problem. I just wish the stock fan wasnt so noisy, it sounds like a small vacuum cleaner :(
Reply to randomizer
There are 1165 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
