Closed Solved
Device manager- PCI Simple communications controller (problem)
Is this a modem issue and how do I fix it? I can't seem to find a driver for this anywhere...
11 answers Last reply Best Answer
More about device manager simple communications controller problem
  1. This usually means the modem driver is missing.
  2. What is the make and model of your board?
    Hi, its in my sig
    MB Brand : Asus
    MB Model : P8P67 WS REVOLUTION
  4. Best answer
    Download this driver form the asus site!
    Version 7.0.0.1118
    Description -MEI
    -Intel Management Engine Interface V7.0.0.1118 for 32/64bit Windows XP & Windows Vista & Windows 7.(WHQL)
    File Size
    258,92 (MBytes) 2011.04.29 update
    http://www.asus.com/Motherboards/Intel_Socket_1155/P8P67_WS_Revolution/#download
    SELECT OS , then open utilities tab !
    Version 7.0.0.1118
    Description -MEI
    File Size
    I'm getting Version 7.0.0.1144 newer is better?
  6. Yes , pick the newer one you found!
  7. Let me know , that should fix it !
    Thanks bro! Fixed!!!
  9. Best answer selected by benson733.
  10. Your Welcome !
  11. This topic has been closed by Area51reopened
Drivers Device Manager Controller PCI Modem Communications Windows 7
