Tom's Hardware > Forum > Computer Peripherals > Webcam > Logitech and XP Problem
Forum Computer Peripherals : Webcam - Logitech and XP Problem
Archived from groups: alt.comp.periphs.webcam (More info?)
This is probably not uncommon, but it's driving me nuts...I've installed
Logitech's QuickCam Messenger. It worked well on my system when I only had
256MB ram, but seems to be choking at 768MB which makes no sense.
When I start the cam up, it freezes up my mouse, but not my keyboard. Very
weird. I'm using a Microsoft Wireless Optical Mouse 1.0 and running Office
XP Professional with SP1. The rest of my specs are:
Windows XP Professional Version 2002
AMD Athlon (tm) processor
801MHz
768MB of Ram
Any ideas/Suggestions?
Thanks Mr. Gee
Sponsored Links
On Sun, 28 Nov 2004 16:30:52 -0500, "Mr. Gee"
You may have gotten some bad ram. Take the ram out and see if it
works. Happened to me once. Got a new MB, etc, and then Found the
ram was causing the problem.
Reply to Anonymous
I agree with Si...replace your new ram with the old and see if the problem
disappears. Bad RAM has been known quite often to cause many weird problems.
Check it now so that it may be returned if bad. As soon as you said you
upped the RAM I knew that would probably be the problem, or perhaps you
didn't use the right knid of RAM. The machines are pretty sensitive to the
right kind of RAM
Regards, David
"Si Ballenger" <shb*NO*SPAM*@comporium.net> wrote in message
news:41aa4e95.255378885@news.comporium.net...
Reply to Anonymous
I am having the exact same problem. I have an Intel HP laptop with XP
SP1 and 2GB ram. Same Microsoft Wireless Multimedia Keyboard / Mouse
combo. When Cam is running mouse reacts like in molasses. Turn the
camera off and everything goes back to normal. Makes camera impossible
to use. Any ideas?
Shayne
problem
problems.
you
you
to the
> right kind of RAM
> Regards, David
installed
only had
keyboard. Very
Office
Reply to Anonymous
my puter maker told me not to use more than 512 mbs of sdram..
i had over that and the whole puter choked after awhile...
hope that helps...
william
When things can't get any worse, they simplify themselves by getting a whole
lot worse then complicated. A complete and utter disaster is the simplest
thing in the world; it's preventing one that's complex. (Janet Morris)
Cost effective domain hosting with all the goodies via me.
"Rough Drafts Live On Stage" & "W. K. Mahler" $5 each.
Exclusively at http://www.mahlers.com & http://www.wkmahler.com
http://www.soundclick.com/bands/4/wkmahlermusic.htm
"Mr. Gee" <derbecker_@sympatico.ca> wrote in message
news:dsrqd.2661$kI6.170612@news20.bellglobal.com...
> 801MHz
> 768MB of Ram
> Thanks Mr. Gee
Reply to Anonymous
There are 1231 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
