Hi All,
Here is the problem that I am having with my network explained from square one. I’ll explain everything from beginning to present.
First let me start by explaining my network lay out.
I have 1 main server (PDC) at the my main site and 1 DC at each of my 2 off site locations. The names of these are Jelly (PDC), Isleta (DC), and Butter2 (DC). All of these locations are connected to each other thru a VWAN that is maintained by my ISP.
On my main server I had two NICs that were both setup with the following IP addresses 192.168.1.8, 192.168.1.10.
Which both of these NICs are set up to be my Primary and Secondary DNS servers.
On March 14th one of the NICs in Jelly (PDC) went out. I replaced it with a new NIC and assigned it with the IP address of the old. But I forgot to uninstall the old one in Windows so I still had a ghost NIC installed which was conflicting with the new NIC. But since I first posted this problem someone has told me how to uninstall ghost hardware so I am no longer having conflicts with that. I have also disabled one of the NICs like several other people have suggested.
But ever since this has happened I have been getting replication errors in my logs. These are the warnings and errors that I have been getting..
Active Directory could not resolve the following DNS host name of the source domain controller to an IP address. This error prevents additions, deletions and changes in Active Directory from replicating between one or more domain controllers in the forest. Security groups, group policy, users and computers and their passwords will be inconsistent between domain controllers until this error is resolved, potentially affecting logon authentication and access to network resources.
Source domain controller:
BERNALILLO
Failing DNS host name:
4b2ee228-5395-452f-967c-139b1ac65dc9._msdcs.PBJFS.local
NOTE: By default, only up to 10 DNS failures are shown for any given 12 hour period, even if more than 10 failures occur. To log all individual failure events, set the following diagnostics registry value to 1:
1) If the source domain controller is no longer functioning or its operating system has been reinstalled with a different computer name or NTDSDSA object GUID, remove the source domain controller's metadata with ntdsutil.exe, using the steps outlined in MSKB article 216498.
2) Confirm that the source domain controller is running Active directory and is accessible on the network by typing "net view <source DC name>" or "ping <source DC name>".
3) Verify that the source domain controller is using a valid DNS server for DNS services, and that the source domain controller's host record and CNAME record are correctly registered, using the DNS Enhanced version of DCDIAG.EXE available on http://www.microsoft.com/dns
dcdiag /testns
4) Verify that that this destination domain controller is using a valid DNS server for DNS services, by running the DNS Enhanced version of DCDIAG.EXE command on the console of the destination domain controller, as follows:
Additional Data
Error value:
11004 The requested name is valid, but no data of the requested type was found.
After talking to several people in other forums they have told me to do a dcdiag.exe test. Here are the results of those tests on all 3 servers. The first will be on the (PDC) main server “Jelly”, followed by Butter2 (DC), then Isleta (DC).
Testing server: Default-First-SiteBUTTER2
Starting test: Replications
REPLICATION-RECEIVED LATENCY WARNING
BUTTER2: Current time is 2006-04-06 16:14:11.
CN=Schema,CN=Configuration,DC=PBJFS,DC=local
Last replication recieved from BERNALILLO at 2005-10-22 09:56:52.
WARNING: This latency is over the Tombstone Lifetime of 60 days!
Last replication recieved from BERNALILLO at 2005-10-22 09:57:23.
DC=PBJFS,DC=local
Last replication recieved from BERNALILLO at 2005-10-22 09:56:53.
......................... BUTTER2 passed test Replications
Starting test: NCSecDesc
......................... BUTTER2 passed test NCSecDesc
Starting test: NetLogons
......................... BUTTER2 passed test NetLogons
Starting test: Advertising
......................... BUTTER2 passed test Advertising
Starting test: KnowsOfRoleHolders
......................... BUTTER2 passed test KnowsOfRoleHolders
Starting test: RidManager
......................... BUTTER2 passed test RidManager
Starting test: MachineAccount
......................... BUTTER2 passed test MachineAccount
Starting test: Services
......................... BUTTER2 passed test Services
Starting test: ObjectsReplicated
......................... BUTTER2 passed test ObjectsReplicated
Starting test: frssysvol
......................... BUTTER2 passed test frssysvol
Starting test: frsevent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... BUTTER2 failed test frsevent
Starting test: kccevent
An Error Event occured. EventID: 0xC000066D
Time Generated: 04/06/2006 16:06:00
(Event String could not be retrieved)
An Warning Event occured. EventID: 0x80000785
Event String: The attempt to establish a replication link for
Time Generated: 04/06/2006 16:06:01
Time Generated: 04/06/2006 16:06:22
......................... BUTTER2 failed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0xC0000007
Time Generated: 04/06/2006 15:17:34
Event String: The kerberos subsystem encountered a PAC
An Error Event occured. EventID: 0x00000457
Time Generated: 04/06/2006 16:03:49
......................... BUTTER2 failed test systemlog
Starting test: VerifyReferences
......................... BUTTER2 passed test VerifyReferences
Running partition tests on : Schema
Starting test: CrossRefValidation
......................... Schema passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : PBJFS
......................... PBJFS passed test CrossRefValidation
......................... PBJFS passed test CheckSDRefDom
Running enterprise tests on : PBJFS.local
Starting test: Intersite
......................... PBJFS.local passed test Intersite
Starting test: FsmoCheck
......................... PBJFS.local passed test FsmoCheck
DNS Tests are running and not hung. Please wait a few minutes...
Running partition tests on : ForestDnsZones
Running partition tests on : DomainDnsZones
Starting test: DNS
Test results for domain controllers:
DC: isleta.PBJFS.local
Domain: PBJFS.local
TEST: Forwarders/Root hints (Forw)
Error: Root hints list has invalid root hint server: a.root-servers.net. (198.41.0.4)
Error: Root hints list has invalid root hint server: b.root-servers.net. (192.228.79.201)
Error: Root hints list has invalid root hint server: c.root-servers.net. (192.33.4.12)
Error: Root hints list has invalid root hint server: d.root-servers.net. (128.8.10.90)
Error: Root hints list has invalid root hint server: e.root-servers.net. (192.203.230.10)
Error: Root hints list has invalid root hint server: f.root-servers.net. (192.5.5.241)
Error: Root hints list has invalid root hint server: g.root-servers.net. (192.112.36.4)
Error: Root hints list has invalid root hint server: h.root-servers.net. (128.63.2.53)
Error: Root hints list has invalid root hint server: i.root-servers.net. (192.36.148.17)
Error: Root hints list has invalid root hint server: j.root-servers.net. (192.58.128.30)
Error: Root hints list has invalid root hint server: k.root-servers.net. (193.0.14.129)
Error: Root hints list has invalid root hint server: l.root-servers.net. (198.32.64.12)
Error: Root hints list has invalid root hint server: m.root-servers.net. (202.12.27.33)
TEST: Delegations (Del)
Warning: DNS server: jelly.sv.jelly.local.org. IP: <Unavailable> Failure:Missing glue A record
Summary of test results for DNS servers used by the above domain controllers:
DNS server: 128.63.2.53 (h.root-servers.net.)
1 test failure on this DNS server
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 128.63.2.53
DNS server: 128.8.10.90 (d.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 128.8.10.90
DNS server: 192.112.36.4 (g.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.112.36.4
DNS server: 192.203.230.10 (e.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.203.230.10
DNS server: 192.228.79.201 (b.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.228.79.201
DNS server: 192.33.4.12 (c.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.33.4.12
DNS server: 192.36.148.17 (i.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.36.148.17
DNS server: 192.5.5.241 (f.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.5.5.241
DNS server: 192.58.128.30 (j.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 192.58.128.30
DNS server: 193.0.14.129 (k.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 193.0.14.129
DNS server: 198.32.64.12 (l.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 198.32.64.12
DNS server: 198.41.0.4 (a.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 198.41.0.4
DNS server: 202.12.27.33 (m.root-servers.net.)
This is not a valid DNS server. PTR record query for the 1.0.0.127.in-addr.arpa. failed on the DNS server 202.12.27.33
Hm... I've never had a setup with two nics in one machine being the primary and secondary dns. I guess if it was working before though that must not be the issue.
Are you able to ping jelly from the other sites via ip and full dns name (ie, jelly.domain.com)? If you can't ping the machine via dns name then it definatly isn't going to replicate
Check your forward lookup zone on all of the domain controllers and see what host record they have in there for jelly. Does it show an IP and if so is it the right one?
I have never givin one computer two IPs on two nics and hooked it up to the same network before. I wonder if there need to be two host entries in the forward lookup zone for each network card. Or if two entries were created when you added the other nic and they are conflicting. I guess if you see two entries for jelly right now try removing one. I could see dns getting confused by trying to resolve one host to two IPs, lol.
