I wanted to post this question on the Sticky "Introduction to Watercooling", but as it's locked I'll ask it here.
The diagrams I've seen for routing the water tubes through the system always start with the CPU, for example from Zalman:
The total amount of heat removed from the computer would be greatest if the water was pumped to the components in order of coolest to hottest, as is done for heat exchangers. So, for instance, I'd think that pumping from northbridge -> memory -> graphics -> CPU would maximise the total heat transfer. I may have some components backwards, but certainly the CPU is hotter than the northbridge and memory. If I need to clarify why this would maximise the heat transfer, I will, but I'm leaving that out for now to try to be a little more brief than my previous posts.
I also thought about wanting to keep certain parts cooler than others, but in my experience the ram and northbridge are happier cooler than the CPU, so it again makes just as much sense to have these sooner rather than later on the loop. In short, what is the reason behind the recommended loop order?
