I just tried to set up sli with 2 gtx 8800' s on a striker extreme and I dont seem gain any higher scoring in 3d mark 2006 from using 1 card
System specs :
6600 core 2 oc two 3.5 ghz
asus striker extreme motherboard
2 gig corsiar memery ddr 800 4,4,4,12
ocz gamer 700 watt power supply
3 120mm fans , 2 90mm fans & a big side cover fan
wd 150 gig rapter hard drive
samsung dvd drive
samsung floppy drive
Dell 30 inch monitor
My question is am I hooking everthing up right ? Does it matter which conection the link cable goes on to connect the two card.....front one or back one?
Also should I be connecting the monitor to a certain dvi output and on which card?
Anything in bios I should do?
windows says I,m in sli and also the memory in bios setup says its in sli so I dont understand why no performance boost.
Any suggestions greatly appreciated. Thanks in advance
Sponsored Links
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > SLI Problem
There are 660 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
