Well tell me if you can figure this out!
I put my 8800GTX in pci-x slot one, powers up but no screen. If I put it in PCI-x slot 2 I get boot screen but POST says that it is in the secondary slot and needs to be in the primary slot. When I put it in pci-x slot 3, same issue as when in slot 1. Now to make it even weirder when I have the 8800 in slot 2 and a 6600 LE in slot one it says that I have a card in the 2 and 3 slot and slot 3 card needs to be moved to the primary pci-x slot. When I remove the 8800gtx and have the 6200le by itself in slot one everything is hunkey dorey and boots to windows fine. I had bios revision 0402 and call tech support and they had me load bios 0302 and still no go
Here is my system specs:
E6600
striker extreme
2gb corsair dominator pc6400
OCZ Gamexstreem 700w psu
Audigy x-fi Fatal1ty
Now I have taken all of these cards out and still have the samy issue and have tried with a single bank of cheap ddr2 memory to boot (no pun intended)
Thanks
Sean
Network Engineer
MCSE:Security, MCSA:Security, CCNA, Network+, Security+, A+
E6600
striker extreme
Thanks
Sean
Network Engineer
