Archived from groups: alt.comp.periphs.webcam (More info?)
WebCamSplitter™ (http://www.very-soft.com)
It's known that two or more applications cannot use the same stream
from the same webcam at the same time. If one application captures a
video source,another
application cannot reach it because the source is locked. Typical
example: you need to give a videoconference with two friends or
partners at once. If your
videoconference software does not support multiple conferences, you
will have to start two instances of the same software. Unfortunately,
in this case you
may get into trouble because one application will translate video, and
the other one will not. What is the solution? It's simple - just use
WebCamSplitter.
Using WebCamSplitter, you can share a video stream from your single
webcam between ANY number of applications. You can plan multiple
videoconferences. You
can upload images from your cam and have a chat at the same time. You
can broadcast your video to the world and do many other things.
Features
WebCamSplitter is a unique all-in-box product. Besides the main
function, that is sharing a video source, it allows to deal with a lot
of really helpful
things:
* Customization of input/output resolutions. You can use a video stream
of any resolution mode from the list of webcam supported resolution
modes,
independently for input and output. This allows to customize your video
as you wish
* Preview for every application that is used with WebCamSplitter
* Preview for the output video stream dependent application that is
used by WebCamSplitter
* Digital Zoom and Pan for every application that is used by
WebCamSplitter
* Desirable frame rate in a video stream
* Video stream desirable processing quality
* User-friendly interface and detailed help
Besides, WebCamSplitter is always available via system tray just like
your ICQ, AIM or Yahoo IM.
System requirements
Video capture device basic requirements:
* DirectX-compatible
* RGB24 color model support
* WebCamSplitter resolution list support:
1. 160x120
2. 176x144
3. 320x240 (default)
4. 352x288
5. 640x480
Requirements:
* Operating system: Windows 2000/XP
* Processor: Intel Pentium® (Intel Pentium III or higher
recommended)
* Random access memory (RAM): 128 Mb or higher
* Additional requirements: DirectX 8.1 (as usual it goes with a
webcam driver installation CD)
Please visit for more information: http://www.very-soft.com Have a problem with your webcam? WebCamSplitter help you!
