Sponsored Links
YES
But, remember for every wireless pc you add, you cut your bandwidth.
example: 54g /2 = 27mbps ....
I'm using the same setup with difernet vendors.
Reply to blue68f100
What brands do you prefer?
Will it matter if my access point was the same brand as my router?
Reply to tendercare
For best performace it's always better to use the same chipset. So see what is being used is the wireless pc then match the AP to it. If your wireless supports large packets, use it. It will double the wireless connection speed (108, 125 mbps vs 54).
Here is what I used to decide my setup 2yrs ago.
http://homepage.mac.com/techedgeezine/2004-0402_g-turbo_shootout1.htm
Remember this article is old, but still applys today.
Reply to blue68f100
Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > pc1 wired, pc2 wireless?
There are 646 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
