I'm hoping this will be the final list before I order everything. I just want to make sure everything checks out okay.
Case: LIAN LI PC-V1000APlus II Silver Aluminum ATX Mid Tower Computer Case - Retail
Mobo: ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel Motherboard - Retail
CPU: Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
GPU: eVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
CPU Coller: ZALMAN CNPS9500 LED 92mm 2 Ball Cooling Fan with Heatsink - Retail
RAM:CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4 - Retail
HDD: Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM (x2)
PSU: SeaSonic M12 SS-600HM ATX12V/ EPS12V 600W Power Supply - Retail
DVD Burner: NEC Black 16X DVD+/-RW -OEM
I want to build a system that I will last me for at least the next 3-4 years, with plenty of expansion room. Okay I'm still not sure on the RAM or PSU. Would you reccommend I get the 700W PSU or will the 600W be enough for future expansions. Planning to spend around $2100 seeing as my current rig is over 7 years old. This will be my first home build.
