I just recently bought two silenx fans rated at 14db with an output of 72CFM.
Because they put out so much air and run at a fast 1300rpm they make a lot of "wind" noise.
I don't really need all of this extra cooling power, I just wanted quiet fans.
Too remedy these windy fans, I downloaded Speedfan. I cannot however figure out how to lower the rpm's of the fans (they are plugged via 3pin into the motherboard).
Does anyone know how I can lower the speed of the fans and if not, are there any other programs I can use to adjust fan speed.
Thank you
Thank you
