Tom's Hardware > Forum > Computer Peripherals > Webcam > Light sensitivity problem with Logitec 4000 Pro
Forum Computer Peripherals : Webcam - Light sensitivity problem with Logitec 4000 Pro
Archived from groups: alt.comp.periphs.webcam (More info?)
I have a Logitec 4000 Pro on 24 hrs and at dawn if fails to adjust to
daylight properly. (image is bleached)
Note: It does not face the rising sun.
Any ideas or good practice to prevent the camera getting stuck like this
Thanks
M
Sponsored Links
Although I'm not familiar with this particular model, it may have a
fixed iris that is designed for indoor use only.
If you point it outside, the overwhelming amount of light will cause
the CCD sensor to smear and produce a washed out hazy image (and will
eventually permanently tint the RGB filters on the sensor).
Nerdman
http://www.nerdman.com
16 Live Webcams Document Life of Nerd!
Reply to NerdMan
On Mon, 7 Feb 2005 18:01:30 +0000 (UTC), "Mettá"
>Thanks
>M
Hi - I have had this camera on 24/7 (mostly) for well over a year and
have not noticed this problem. No suggestions though as I've done
nothing but have the camera connected; outdoors most of the year;
inside over winter (now).
"live" cam:
http://home.nycap.rr.com/willowpond/pondcam/
check the "last 60 min" page around sunrise and see how this camera
responds to dawn:
http://home.nycap.rr.com/willowpon [...] 01hour.htm
Reply to Anonymous
celeste: what software are you running??
Reply to Anonymous
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
