Hey, my parents have been experiencing problems with our older Dell 4550 (yeah i know it's a dell). When the pc starts up, sometimes it gives them an error saying that the graphics card doesn't have the power cable connected to it when it really is.
So, while it was occuring, I went into the room and opened up the case with the power off of course. I unplugged and re-plugged in the molex connector giving it power and it seemed to solve the problem. today, my parents told me that it has happened more frequently today. Sometimes the pc will boot up and sometimes it won't. They ahve to turn the system on and off again sometimes disconnecting the whole system just to get it to work...
This ONLY seems to happen at startup. My dad said something about "the system continuously running" which he did not explain.
My big question is, what could be the problem?
I think it either is the psu going or the molex cable isn't together right. I will check the latter soon after posting this.
Here's the system's specs (if you want to know)
-p4B 2.4ghz
-1280 mb ram
-intel 845PE motherboard
-Ati X800gto AGP card
-60 gb hard drive.
Also, I may swap out the Ati (new) card for my old mx 420 just to get the system to work without issues until I can get a new psu if it's dying...
I know this was long, but I wanted to make sure that I got enough info for everone.
Thank you soooo much for any help/suggestions.
-p4B 2.4ghz
-1280 mb ram
-60 gb hard drive.
