Intel Core 2 Duo E6600 Socket 775 2.4GHz
Intel P965 Socket 775 ATX Audio DDR2
Seagate Barracuda 7200.10 250GB S300
DabsValue 480W PSU Gold 12cm SATA PFC
- http://www.dabs.com/ProductView.aspx?Quicklinx=39N9
XFX GeForce 7900GT 256MB DDR3 PCIE Dual DVI
- http://www.dabs.com/productview.aspx?Quicklinx=40YQ&CategorySelectedId=11137&PageMode=1&NavigationKey=11137,50544
2 old IDE optical drives i am going to salvage.
Kingston ValueRAM 1024Mb DDR2 667MHz 240Pin Memory
Okay thats the lowdown, questions i need to ask -
1) will that power supply work for everything including the gfx card (i provided the 2 links)
2) will my old IDE drives work on the newer IDE sockets on my mobo
while you are there tell me what you think lol.
Please help! Thanks so so so so so much.
