G
Guest
Guest
Archived from groups: microsoft.public.win2000.general (More info?)
This is on a W2000 workstation.
I have a batch program which runs my backup from the command line.
First a backup is made, then the backup is zipped, and finally the zipped
backup is copied to a CD/RW.
Since applying SP4 I often get the message "Incorrect Parameter" with the
copy command. The command is: COPY D:\Backup\daily.zip Y:\Sunday.zip, where
Y is my CD/RW.
Copying it via the Explorer just works fine..
Any suggestions?
Thanks
Y is my CD/RW.
Any suggestions?
Thanks
